Avatar vs. The Avengers - Specific Comparison - AVS Forum | Home Theater Discussions And Reviews
Old 07-03-2012, 09:30 AM - Thread Starter
Closet Geek's Avatar
Quoted: 164 Post(s)
Liked: 170
I'm trying to get a reasonable gauge of 3D technologies comparing Real 3D or something comparable vs. IMAX 3D.
Has anyone seen Avatar and The Avengers in both 3D formats?
Since Avatar was supposedly such a great 3D presentation, how does the Real 3D of Avatar compare to the IMAX 3D of the Avengers?
How does the Real 3D of both movies compare to each other?
First of all, I'm using these two movies because, while I have not seen Avatar in 3D, I keep reading of its regard in the 3D community so I figure it makes for a valid comparison. I have; however, seen The Avengers in both 3D formats with the first being in IMAX 3D, which has changed my opinion about the possibilities of 3D (I'm not a 3D proponent). I'm not wanting to compare the movies themselves, just the 3D presentation of each. I'm doing this because I keep reading reviews and opinions about "3D" but no one ever explains which format it was viewed in almost as if it shouldn't matter.
So with the above, I'm trying to find out if a, supposedly, great 3D presentation in Real 3D can compare to what I regard as an at least very good IMAX 3D presentation? The other viewings and comparisons are to establish benchmarks for understanding the quality of each format.
Closet Geek is offline
Old 07-09-2012, 06:00 AM
bontrager's Avatar
Quoted: 101 Post(s)
Liked: 71
I have seen both in IMAX 3D. Avatar (have not seen the READ 3D presentation) was shot in 3D while the Avengers was converted to 3D before the release.
If memory serves me correctly Avatar had more depth to the presentation. Neither one had a considerable amount of "pop out" but I am beginning to think that more forum members are beginning to think that too much "pop out" is not life like. It seems that animated 3D movies have a little more of this feature if that is what you are looking for.
Just learned this the other day while viewing the new Spiderman at IMAX. The movie was available both in REAL 3D and IMAX 3D. While getting my 3D glasses I asked if the REAL 3D glasses would work at the IMAX showing and vice versa. The answer is "no" since IMAX show s a separate image for each eye and REAL 3D does not; so Imax may show more of a true 3D image.
Based on this I would say that the IMAX presentation would always be superior.
I guess I have really haven't addressed your question but since I spent the time typing this I don't want to delete.
Peace.
bontrager is offline
Old 07-09-2012, 08:20 AM
Lee Stewart's Avatar
Liked: 51
Peace.
IMAX 3D = Linear Polarization
RealD = Circular Polarization
That is why the glasses are incompatible with each other.
Lee Stewart is offline
Old 07-09-2012, 11:47 AM
BleedOrange11's Avatar
The way that the 3D was created by the filmmakers matters much more than if you see the 3D in IMAX, RealD, or home theater 3D. If those three venues are equally calibrated and the viewer is at recommended seating distance, then the 3D will look proportionally the same, just with different sized screens. (A bigger screen does make a bit of difference, and sometimes IMAX does get a different cut with an exclusive aspect ratio though.) The movie is what matters most if the projection quality doesn't suck. (IMAX tends to have better projector calibration than RealD, but that really depends on individual theaters.)
The Avengers was a good conversion, but overall it was middle-of-the-road 3D. Stereoscopic 3D makes different impressions on different people, but in my opinion, you aren't even close to having seen 3D at its maximum potential. Avatar wins--no contest.
I saw Avatar and The Avengers in nicely-calibrated RealD 3D theaters, and I've seen clips of Avatar at home on my 3DTV.
BleedOrange11 is online now
Old 07-09-2012, 01:20 PM - Thread Starter
Quoted: 164 Post(s)
Liked: 170
Post converted films aren't as good. I get it and expect that. But what I'm trying to isolate is when people say 3D is excellent or sucks, no one ever speaks to the format, IMAX 3D or Real 3D, even critics. Should we assume that their opinion is based on an IMAX presentation? Or more to the point of what I'm trying to find out, should the format matter?
The AVengers is the only IMAX presentation that I've seen. Before that, I would tell you that all 3D is a waste of money because of the handful of movies I've seen (in Real 3D), the effect has been marginal at best and not even that 50% of the time. Had I seen The Avengers in Real 3D first I would have said the same thing based on the fact that my second viewing was....marginal at best. I can't speak to specifics but I believe the theaters in my area are pretty decent and would have at least above average calibration for 3D presentation. And I probably would not have gone back to see it in 3D IMAX or otherwise. Now....with The Amazing Spiderman and Dark Knight Rises, where should my expectations lie with viewing format? If I'm going to consider 3D should it automatically be IMAX, just so happens to be the more expensive...for the supposedly same effect? Or again, does the format matter and the only thing that IMAX should offer is a bigger screen? Or is 3D so much across the board that the only way to know is to go view each movie in each format each time?
Old 07-09-2012, 02:26 PM
Yes, the theater that the reviewer saw it at does matter if the projection quality was bad. If he says, "the 3D was good/bad" and just leaves it there, that doesn't really tell you anything about the nature of the 3D, the quality of his theater, his taste in 3D, or why he had a good/bad experience. Those kind of comments don't help anyone.
Projection quality is literally different across the board at every single theater with every single projector. You can't depend on reviewers to make the best viewing decision for you. You just have try out different 3D movies at different theaters and see which one has consistent projection and a good price to satisfy your needs. If all dimly lit scenes look more like 2D than 3D, try a different theater the next time you go see 3D.
Personally, I always have a better experience at my local digital IMAX. The screen is bigger, the sound is better, the calibration is perfect, the chairs are tall, they always get the exclusive aspect ratios, and the theater is empty during Mon.-Thur. $10 matinees. You just have to decide if the extra ticket price is worth the improvements you get over your local theaters.
Old 07-09-2012, 02:43 PM
Steve Tack's Avatar
But what I'm trying to isolate is when people say 3D is excellent or sucks, no one ever speaks to the format, IMAX 3D or Real 3D, even critics. Should we assume that their opinion is based on an IMAX presentation? Or more to the point of what I'm trying to find out, should the format matter? ... Now....with The Amazing Spiderman and Dark Knight Rises, where should my expectations lie with viewing format? If I'm going to consider 3D should it automatically be IMAX, just so happens to be the more expensive...for the supposedly same effect? Or again, does the format matter and the only thing that IMAX should offer is a bigger screen? Or is 3D so much across the board that the only way to know is to go view each movie in each format each time?
My understanding is that RealD 3D lets you tilt your head and maintain the 3D effect because of the circular polarized glasses and IMAX 3D tends to be brighter (supposedly). But I think those are really the only main differences. In each case, the separation between the left and right images is going to be the same, so I would expect the 3D effect to be very similar.
It's worth noting that not everyone gets the same effect from stereoscopic 3D and some folks even get zero effect, so it does vary from person to person. Add in the fact that there is a wide range of 3D quality and depth from one movie to the next, and you've got a lot of variables.
By the way, The Dark Knight Rises will not be in 3D. On a side note, I saw the IMAX version of The Dark Knight, which has some native IMAX film format scenes and I would say that the super detailed image was cooler than any 3D effect. It should be worth it to check out The Dark Knight Rises in IMAX, since I understand that even a larger number of scenes were shot in IMAX for that one.
Steve Tack is offline
Old 07-09-2012, 03:33 PM - Thread Starter
Quoted: 164 Post(s)
Liked: 170
Thanks guys, I've found both of your comments to be helpful. I have tried Real 3D in two different theaters but now that I think of it, they're the same chain, AMC, and are in fact right down the street from each other, probably only 3 miles or so apart. So perhaps I'll try Weherenberg. I actually knew about DKR not being in 3D and actually did plan to see that one in IMAX.
Old 07-09-2012, 04:53 PM
Liked: 51
IMAX 3D is brighter because they use dual projectors while RealD uses a single projector. IMAX went with Linear polarization because it has a better extinction ratio then circular polarization. The drawback is very limited head movement.
Only IMAX 15/70 theaters will be showing The Dark Knight Rises in true IMAX (for the 60 minutes of real IMAX footage shot for the movie). Digital IMAX will not.
Old 07-11-2012, 05:15 PM
blastermaster's Avatar
Quoted: 433 Post(s)
Liked: 550
So is this one going to be another combination of switching aspect ratios when the IMAX scenes occur?
Video: Optoma HD3300, Panamorph UH480, Darbee Darblet, Samsung BD D6700 Blu Ray player, DIY Seymour Centerstage XD 138" Curved Screen
LCR - Tannoy DC12i, Sides - Tannoy IW63, Rears - Tannoy Saturn DC6ti Bookshelf, Ceilings - Tannoy CMS 603DC (TF), Tannoy CMS 601DC (TR), 3 Micro Marty/1 Full Marty DIY subs
Amplification: Emotiva XPA-3, Emotiva XPA-2, Outlaw Audio 7700, 2x Inuke 6000DSP
Receiver: Anthem MRX 720
blastermaster is online now
Old 07-12-2012, 04:37 PM
mr. wally's Avatar
Quoted: 59 Post(s)
Liked: 78
i find i like digital imax 3d better than real due to greater brightness. small yet noticeable difference.
avengers was a mediocre 3d transfer, nothing special.
2 best 3d movies i have seen are avatar and prometheus, both shot and recorded in full 3d format
mr. wally is offline
Old 07-12-2012, 04:53 PM
Liked: 51
Yes - just like THE DARK KNIGHT and MI4
Old 07-17-2012, 03:30 PM
Steve Tack's Avatar
Yeah, I saw The Dark Knight in a "real" IMAX theater and it was very cool. There's only one of those in the Denver area that I'm aware of (that plays movies rather than documentaries). I'll definitely be checking out the new one in that IMAX theater at some point.
So do the other IMAX branded theaters you see in multiplexes ever use the real 15/70 projectors or do they show this "Digital IMAX" you referred to? I suppose without the huge vertical screen you wouldn't get the same benefit anyway. How can the consumer tell the real 15/70 theaters from the others? Seems like poor branding. Add in IMAX 3D and it's pretty confusing.
Old 07-17-2012, 03:34 PM
Liked: 51
Here is a link that shows all the IMAX theaters in the USA and what IMAX format they use. Do not know how accurate it is.
http://www.lfexaminer.com/theaUSA.htm
Digital IMAX uses dual Christie 2K digital projectors
Old 07-19-2012, 10:59 AM
Steve Tack's Avatar
That does answer something I was curious about. The one "real" IMAX in Denver does indeed appear to be the only one in the area that does 15/70. I never realized how few of those there really are.
Old 07-19-2012, 11:41 AM
Liked: 51
Many have been converted from 15/70 to Digital. They stopped installing new IMAX 15/70 theaters years ago. A 35mm print costs about $1,200. An IMAX 15/70 print costs $45,000. If it's IMAX 15/70 3D - 2 prints are needed - $90,000. The projector lamps cost $4,000 each and have to be replaced 3 or 4 times a year per projector. 2 lamps per projector.
Old 07-19-2012, 11:51 AM - Thread Starter
Quoted: 164 Post(s)
Liked: 170
So is the size of the screen the only thing the viewer loses out on if it's not 15/70? Quality wise everything else is the same (theoretically)?
Old 07-19-2012, 11:56 AM
No, you miss the extra high resolution of 15/70mm film, especially when certain scenes were filmed with 15/70 IMAX cameras.
Old 07-19-2012, 12:19 PM
Liked: 51
Avatar Three Disc Extended Collectors Edition Bd Live Blu Ray , Blu Ray Movies
