Samsung DLP checkerboard help please (I hope I am in the right forum - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-04-2012, 11:40 AM - Thread Starter
Guarddog32's Avatar
I bought one of those 3D Emitter boxes with 4 pair of glasses on Ebay from the 3DTV Corp company and cant get it to work with either my laptop or sony blu ray as the source.
If I try to set it up with my Dell laptop with nvidia 3D vision built into it (with a built in emitter) I hook up the hdmi port on my laptop to the hdmi3/dvi connector on back of TV, then hook the emitter that came with glasses to the 3D sync out 3 pin connector on back of TV, and when I run the setup on nvidia control panel, it tells me that vesa emitter cable is disconnected or stereoscopic 3D is not turned on on tv. (I went into my TV setup screen and 3D is turned onto mode 1.
I will stop for now so i can get some advice on getting my laptop to work with this emitter and glasses kit. I will ask more later about why my Sony 3D blu ray player wont work either.
My Samsung DLP TV is model; HL61A650C1FXZA
Laptop is Dell XPS L702X, Windows7 with Nvidia Stereoscopic 3D Vision with built in emitter and 3D glasses for laptop
The 3D kit I bought from 3DTV Corp is the Gen2Pro / Home Emitter with 4 pair of Glasses.
Thanks so much in advance for any help I can get with this setup...
Rich J
Guarddog32 is offline
post #2 of 8 Old 07-04-2012, 12:37 PM
cjf243's Avatar
cjf243 is offline
post #3 of 8 Old 07-04-2012, 03:33 PM - Thread Starter
Guarddog32's Avatar
Thank you very much, I was able to get it to work with software I had on my laptop already, so I didn't have to buy anything else.
Is there a way to get the PS3 to play in 3D on these old Samsung DLP's that are "3D-Ready" ???
post #4 of 8 Old 07-05-2012, 10:25 AM
ToEhrIsHuman's Avatar
Yeah, sure. Read the article posted above about using the Mitsubishi 3DA-1. I use my PS3 in 3D on my HL-T6187S all the time.
ToEhrIsHuman is offline
post #5 of 8 Old 07-05-2012, 06:44 PM - Thread Starter
Guarddog32's Avatar
Ok, let me rephrase my question, can you hook up your PS3 on these old Samsung DLP's that need checkboard WITHOUT having to buy a 300 device (thats a total ripoff if you ask me)
Thanks for your help by the way
Rich
post #6 of 8 Old 07-07-2012, 12:10 PM
PaulGo's Avatar
Quoted: 133 Post(s)
Liked: 60
Rich
Sorry the TV will not work without a device that converts that output to checkerboard and the PS3 does not. The only Blu-ray player that I know of that has an option to output checkerboard is the Panasonic Blu-ray players plus computer that have an HDMI output that has software that can output checkerboard Cyberlink DVD Ultra).
PaulGo is online now
post #7 of 8 Old 07-10-2012, 08:22 AM - Thread Starter
Guarddog32's Avatar
Hmmmmmmmm ok. I wonder if I can hook up my PS3's hdmi cable to my laptop, then hook up the laptop to the HDMI3 port on the TV, then somehow get the PS3 to play through the Cyberlink PowerDVD 9.6 software installed on my PC that can convert signal to Checker Board format. Ever hear of anyone doing that before?
post #8 of 8 Old 07-11-2012, 01:59 PM
nickels55's Avatar
Liked: 36
No, because you are almost surely going to add some lag time in the process. Make a move with the controller and watch it happen a short moment later.
Look hard - you'll find a 3DA-1 for about $150 somewhere. Totally worth it.
OK I just looked - this is getting more rare by the day. Maybe your best bet is to buy the starter kit for $300 and sell the glasses that come with it.
nickels55 is offline
Reply 3D Content
