How do I convert over-under 3D content to Side-by-side 3D ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-26-2012, 08:33 AM - Thread Starter
Vancomycin's Avatar
Vancomycin is offline
post #2 of 4 Old 08-26-2012, 01:19 PM
johnny905's Avatar
Quoted: 103 Post(s)
Liked: 59
I'm sure there's a way to do it, but why would u want to? I guess if your TV or projector cannot decode over-under I understand, but over-under is already halving the resolution once, slicing the resolution in half the other way on top of that would likely result in a pretty ugly picture compared to the original.
johnny905 is offline
post #3 of 4 Old 08-27-2012, 05:59 PM
MadMyers's Avatar
Quoted: 204 Post(s)
Liked: 123
I'm not aware of a product that does this, but I've not ever looked closely.
Unless it's your only option, you wouldn't want to do this. Side by side and over/under both drop half the resolution either horizontally (Side by side) or vertically (over under). If you would convert from one to the other, you would lose yet another 1/2 resolution, resulting in 1/4 resolution of the original.
MadMyers is offline
post #4 of 4 Old 08-27-2012, 07:33 PM
jnabq's Avatar
Liked: 39
Are you still using the Panasonic TC-P65VT30? Pg. 27 of the manual says you can change the 3D format display to side by side.
jnabq is offline
Reply 3D Content
Blu Ray Movies , Panasonic Viera Tc P65vt30 65 Inch 3d Plasma Hdtv , Plasma Hdtv , Blu Ray Players
