How to play HFR 48/60 FPS mede8er?? - AVS | Home Theater Discussions And Reviews
post #1 of 4 Unread Today, 01:26 PM - Thread Starter
Tobbegutt's Avatar
I have The hobbit and so on, but it seems like the mede8er stalls out on 23.97 fps, and i have set te frame rate to auto and the 23.97 to OFF:
So it should have picked up a faster frame rate IF my AVC file wich are about 70 GB has higher frame rate, im not sure?
I have a BENQ w1300 and it can play 60FPS so im sure my hardware can handle it.
I need some advise here..
I had only two shots at seeing the HFR at my "local" cinema wich is about a couple hour drivig away so i Guess i need to handle this myself..
Tobbegutt is online now
post #2 of 4 Unread Today, 01:51 PM
tomtastic's Avatar
Quoted: 161 Post(s)
Liked: 68
Are you referring to the home release of The Hobbit? They have all been 24 frame so far. Currently nothing in the works for 48 frame, that I've heard.
This line intentionally left blank.
tomtastic is online now
post #3 of 4 Unread Today, 02:07 PM - Thread Starter
Tobbegutt's Avatar
well that explains it then..
Any other Movies that are out wich have higher FPS as im curious of testing out my system??
post #4 of 4 Unread Today, 02:12 PM
Super Moderator
teachsac's Avatar
Quoted: 148 Post(s)
Liked: 193
Nope. It has not been supported up until the new UHD standards.
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself
teachsac is online now
Reply 3D Content
