streaming Blu ray movies - AVS | Home Theater Discussions And Reviews
post #1 of 4 Old Today, 07:09 AM - Thread Starter
gec5741's Avatar
Quoted: 153 Post(s)
Liked: 77
Hi all,
This Christmas I got my first projector finally. I have an Epson 5030UB and have started to dabble for the first time with 3d titles. Now I only own a couple actual blur ray discs which are the hobbit 1 and 2. A coworker gave me a couple files that he said would work in 3d. they are side by side images so watching them on a normal TV their are 2 side by side pictures. I wanted to test this out with my plex setup at home so I put one into my plex folder and gave it a try. After changing the projector 3d setup to side by side it did give me a 3d image. now I'm having a hard time telling if it's better, worse or indifferent as to the quality between this file and actual 3d discs played through my Sony BD player. Like I said I'm new to 3d and all the settings. Seems to me some scenes look very good and others I see what I guess is referred to as ghosting. I've tried to play around with the depth setting and can't tell what's best for this setting. Is it particular to the movie or would I be able to find a depth setting that I'm comfortable with and leave it alone after? Seems like to me 1 is the easiest on my eyes but am I loosing much of the 3d effect by lowering this setting? I really want to enjoy 3d and have people over to show it off but it kind of seems hit or miss to me at this point. Are there other settings I should look at in the 3d setup menu that can adjust things? Are these side by side copies just inferior to the actual disc? I would rather purchase the title anyway myself to have an actual disc to own. But my thought was down the road to get a 3d burner in my pc and turn my discs to files to play through plex like I do with my normal Blu ray discs. If I did would I need to convert them to these side by side type files?
Thanks in advance for any input. I will do more reading on the subject as well.
gec5741 is online now
post #2 of 4 Old Today, 07:38 AM - Thread Starter
gec5741's Avatar
Quoted: 153 Post(s)
Liked: 77
Seems from the reading I've done and someone please correct me if I"m wrong here is this. If it's in side by side or top and bottom that means most likely the disc is a boot leg copy. Also from what I've seen is that these formats will produce a worse picture due to the fact that your not getting the full FPS as it's split in half is this correct? Is it possible to make a digital 3d copy of a 3d disc that you own or should I just not even worry about it. I guess I don't watch 3d all that much and on those occasions it would be fine to just pop the disc in the old blu ray player. I'm just real big into home automation and I love having all my movies available through plex so i can stream them to anywhere but then again 3d I'd really only watch on my projector anyway so again maybe trying to rip them isn't really necessary and not worth the effort. I'd rather not loose PQ in doing so!
post #3 of 4 Unread Today, 02:25 PM
rekbones's Avatar
Quoted: 116 Post(s)
Liked: 80
Yes you can create an ISO file of a 3D disk, but only commercial software as in PowerDVD can play it back. In my opinion its not worth the hassle to use HTPC for full quality 3D, although SBS works fine if you are OK with the half resolution. I am using KODI for everything but 3D where a BR player just works the best.
Smart enough to know better, to old to care
rekbones is online now
post #4 of 4 Unread Today, 03:30 PM - Thread Starter
gec5741's Avatar
Quoted: 153 Post(s)
Liked: 77
Yea kind of what I thought. I'll probably not worry about ripping 3d discs and just use the discs. I don't have a big 3d library anyway.
Reply 3D Content
Gear in this thread - 5030UB by PriceGrabber.com
