UN60ES7150F - PQ Settings - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-28-2012, 10:09 AM - Thread Starter
rmsarma's Avatar
Got the costco deal, any suggestions on the optimal PQ Setting, can't seem to get the display quite set...
1080p freak
rmsarma is offline
post #2 of 3 Old 07-28-2012, 10:21 AM
Otto Pylot's Avatar
Quoted: 1390 Post(s)
Liked: 869
You'll probably hear this a lot but sharing settings between sets is not recommended because of component tolerances from set to set, even within the exact same model. You also have to take into consideration the viewing environment which has a lot to do with overall pq. What looks good on one set can look like crap on another and create a very confusing situation (is it me, my set, or what?). I suggest getting a calibration disk such as AVS HD709 (free), WoW, Spears & Munsil, etc and at least setting the basics; contrast, brightness, sharpness, aspect, etc. That will go a long way in improving pq. Your set won't be calibrated (can't do that without meters) but at least it will have an Accurate Picture Adjustment based on standards.
rmsarma likes this.
Otto Pylot is offline
post #3 of 3 Old 07-28-2012, 12:40 PM - Thread Starter
rmsarma's Avatar
Thx Otto, trying out the AVS HD709
1080p freak
rmsarma is offline
Reply LCD Flat Panel Great Found Deals!
