LG 55LM6700 or 55LM7600 - AVS Forum | Home Theater Discussions And Reviews
Old 10-12-2012, 08:33 AM - Thread Starter
kay11's Avatar
What I have read from the forums is,
7600 is 240Hz while 6700 is 120Hz.
7600 has black bezel while 6700 silver.
Both seem to have local dimming.
Both are glossy screens.
Is 7600 worth the extra money.
I am not going to use it for gaming, so higher refresh rates not useful.
Is 8600 a matte screen?
kay11 is offline
Old 10-18-2012, 04:00 AM
Pooja Lapasia's Avatar
Hello,
if u want to buy a led tv than iam suggest to u go with LG 55LM7600 LED Tv. It's best option for U compression to LG 55LM6700.
Thanx:-
Pooja Lapasia is offline
Old 10-19-2012, 01:10 PM
tolax's Avatar
Personally I would go for the 7600. That being said B&M Frys's are selling the 6700 55" this week for $999. A lot of people matched the price at Sears (+10% price difference) or bestbuy. At that price it is hard to argue with. I believe the 7600 is $1399 which is also competitive when compared to Amazon etc.
Hope this helps.
Tolax
tolax is offline
Old 10-19-2012, 09:14 PM - Thread Starter
kay11's Avatar
Thanks guys, I got the 6700.
999+ tax.
Could not pass this deal which is 40% cheaper, and I like the silver bezel.
I also picked up a Pioneer AV receiver for $75.
kay11 is offline
Old 10-20-2012, 08:04 AM
Duffeymt's Avatar
I just picked up the 6700 and used an old tilt mount from my 6 year old Panasonic 42". I just used the screws from the back of the new LG to secure the mount rails to the back of the TV. The screws were so tiny compared to the screws that fit into my old Panasonic.
Is this OK? Are the screws from the back of the LG intended to be used for mounts? Also, the manual says something about inner spacers - I assume these are the spacers on the screw? The manual says to put these between the TV and the mount, rather than between the screw head and the mount? Which side of the mount should these be on?
Duffeymt is offline
