VIZIO E701i-A3 70-inch $1578 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 05-23-2013, 07:40 PM - Thread Starter
jkjkll's Avatar
Liked: 25
VIZIO E701i-A3 70-inch 1080p 120Hz Razor LED Smart HDTV ($1598, $1578 w/Prime) @ amazon
Normally $1699, hasn't been at this price for a while. I've been waiting for a price drop, it dropped $100 today.
jkjkll is offline
post #2 of 12 Old 05-26-2013, 03:19 PM
neemo6's Avatar
Best Buy also has it for 1599 if you just want to pick it up at a b&m.
PSN: AWDdsm
XBL: ORDEProject
neemo6 is offline
post #3 of 12 Old 05-27-2013, 09:47 PM
Clemsonfan15's Avatar
Y'all think now is a good time to buy this unit? Any idea if the price will drop within the next month?
Clemsonfan15 is offline
post #4 of 12 Old 05-28-2013, 06:05 PM
GatorJZ's Avatar
Quoted: 54 Post(s)
Liked: 61
Best Buy now price matches Amazon.
Samsung UN50HU8550, Vizio P602ui-B3 & Vizio M43‑C1.
GatorJZ is offline
post #5 of 12 Old 06-03-2013, 09:33 AM
Air Supply's Avatar
Except you gotta pay tax at best buy, unlike Amazon.
Add your favorite bass-heavy movies here; http://lfemovies.pbworks.com/
Air Supply is offline
post #6 of 12 Old 06-03-2013, 11:54 AM
queequeg99's Avatar
Picked this up at Costco yesterday for $1579 (plus 2% cash back with my costco AmEx card). It's replacing a 50 inch LG plasma. The other set I was considering was the Sharp 657U (for 20% more money). I liked the LG but it had big glare issues (the Vizio has a relatively matte-like screen while the LG is a mirror). Plus, due to some remodeling work, our great room can now handle a 70 inch set. Picture is great so far, although there is a relatively narrow sweet spot for viewing. I notice washout if I get more than about 25-30 degrees off center.
queequeg99 is offline
post #7 of 12 Old 06-03-2013, 12:01 PM
Air Supply's Avatar
Do wall mount screws come with the TV?
post #8 of 12 Old 06-03-2013, 01:32 PM
queequeg99's Avatar
There are four cosmetic screws that fill the mounting holes. Based on the number of turns it took to remove them, I would never consider using them to mount the TV (way too short). Just go to Home Depot or Lowes and buy four M6 x 20MM bolts for a couple of dollars. You very likely will also want to pick up some washers for the bolts because the back of the set isn't perfectly flat and I needed to use the washers to stand the mounting bracket off from the back of the set. This might vary depending on the type of mount you're using.
post #9 of 12 Old 06-10-2013, 10:06 AM
Air Supply's Avatar
Thanks, got it mounted!
post #10 of 12 Old 01-13-2014, 09:41 AM
jaimecruz's Avatar
HI everyone,
I am a noob at this so sorry if I have dumb questions....
I just picked this TV up and mounts and every cable under the sun...also added the Vizio 5.1 soundbar with wireless rear speakers via subwoofer.
I am taking this week to do all drilling, carving and snaking through walls and hope to have a great end result.
My question is regarding the Vizio Costar which I currently use. It works great with my Toshiba(52in) but now that I am setting up the TV that has built in Apps....I am a little worried about any issues (multiple seem to be duplicate remotes, Interfaces (which one to use).
Should I not use wireless on the TV and dedicate the Costar or vice versa?
I know...alot....but if someone out there has the same setup, maybe I can get some advise...
Jaime
jaimecruz is offline
post #11 of 12 Old 01-13-2014, 09:43 AM
jaimecruz's Avatar
By the way....Loving the info exchange on the forums here....Learning much.:)
jbug likes this.
post #12 of 12 Old 01-14-2014, 07:32 AM
jbug's Avatar
Quoted: 259 Post(s)
Liked: 129
Originally Posted by jaimecruz View Post
By the way....Loving the info exchange on the forums here....Learning much.smile.gif
Welcome Jaime. AVS is the best place I know of for TV info. And, if there is a more active forum for consumer electronics I haven't ran across it yet.
jbug is offline
Reply LCD Flat Panel Great Found Deals!
Vizio E701i A3 Led Hdtv
