Best Plasma & LED-LCD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 07-09-2013, 05:59 PM - Thread Starter
tysonm's Avatar
Hi everyone, I realize this is the "LCD" part of the forum, but I have a question for both LCD and Plasma, but if I need to re-direct my plasma question on the Plasma part of the forum I will gladly do so.
I am helping a few people that asked me which tv's I would recommend. Three of them are leaning towards Plasma and the other three want LED-LCD. I just wanted to know which three tv's would be the best to buy in plasma and which three would be the best to buy for LED.
The price range is around $300 - $1000 for a new tv. I am trying to target tv's for them that are a good bang for your buck or tv's with great features. If you guys could help me out that would be great!
tysonm is offline
post #2 of 7 Old 07-09-2013, 08:02 PM
Mad Norseman's Avatar
Liked: 101
But what sizes of HDTV are they wanting??? (That will make a big difference).
I'm partial to plasmas for their superior black levels and shadow detail, FAR better off-axis viewing, no motion blurring issues, and more natural color - and to top it off, they're less expensive than LCDs/LEDs too!
Check B&H Photo Video for some of the better deals for either...good luck!
http://www.bhphotovideo.com/c/search?atclk=Display+Type_Plasma&ci=4919&N=4294544032+4292350633
The Insane Pink Care Bear's Home Theater Set Up:
Marantz AV 8801 Processor, Emotiva XPR-5 Amplifier, Panasonic 65" ST30 Plasma, Yamaha BD-S2900 Blu-ray, Yamaha CDC-697 CD Player, Yamaha TT-500U Turntable, w/Signet TK5e, JBL ES100 Fronts, JBL LC2 Center, JBL ES30 Surrounds & 2 JBL ES250P Subwoofers
Mad Norseman is offline
post #3 of 7 Old 07-09-2013, 08:08 PM
smurraybhm's Avatar
Quoted: 1469 Post(s)
Liked: 1760
and then walk into a Best Buy or another local retailer and get them to price match B&H, unless you happen to live in NYC.
RIP Cricket - my pug and little buddy Jan. 10, 2017
Panasonic 60VT60 (cal by DNice)
Ascend's with RAAL, Love my PSA v1800 and a 7.2.4 speaker config, Oppo 203 w/ 2500+ blu-rays and growing. Yes I still have HD-DVDs too.
smurraybhm is offline
post #4 of 7 Old 07-10-2013, 01:05 PM - Thread Starter
tysonm's Avatar
basically between 42" - 54" tv's. They are mostly concerned about picture quality. There isn't very many electronic stores around my area since they have been closed down, Best Buy being one of them. So it's hard to look at a lot of different tv's. I have seen some at Walmart, but they have them running off a cheap receiver or something because the picture quality seems to have a lot of static or motion blur on almost all of them, which I don't know if it's how they have them setup or if thats how the tv quality really is.
tysonm is offline
post #5 of 7 Old 07-10-2013, 04:54 PM
Liked: 101
Then if you don't have many opportunities for 'first-hand' shopping, then I'd rely on Home Theater Magazine's "Top Picks" ratings and recommendations: http://www.hometheater.com/content/top-picks-flat-panels
I haven't seen a bad recommendation from them yet!
(P.S. - all the expect reviewers own plasmas for their personal displays which should tell you something! But if you're a video gamer I'd stick with LCD/LED sets because of the stationary menus and score boxes, etc.).
post #6 of 7 Old 07-10-2013, 06:27 PM - Thread Starter
tysonm's Avatar
Awesome, thank you!!
tysonm is offline
post #7 of 7 Old 07-11-2013, 03:59 AM
GatorJZ's Avatar
Quoted: 54 Post(s)
Liked: 61
OP: You posted this in the wrong place. This is the "found deals" sub-forum.
Samsung UN50HU8550, Vizio P602ui-B3 & Vizio M43‑C1.
GatorJZ is offline
Reply LCD Flat Panel Great Found Deals!
