Samsung PN60E550 60" Plasma $1297.99 at Amazon - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-31-2012, 01:11 AM - Thread Starter
Jelorian's Avatar
What do you guys think of this unit?
Fry's and B&H have similar pricing. Some other online retailers are bundling it with a BD Player.
http://www.amazon.com/Samsung-PN60E550-60-Inch-1080p-Plasma/dp/B0077D1LTW/ref=sr_1_1?ie=UTF8&qid=1346396853&sr=8-1&keywords=samsung+60%22+plasma
Jelorian is offline
post #2 of 5 Old 09-02-2012, 07:59 AM
tylerSC's Avatar
Quoted: 721 Post(s)
Liked: 166
The video processing is not as good on the E550 as it is on the upper series 6500, 7000, 8000. Images are not as sharp, and the glossy screen is subject to glare. And the 60E550 uses a pentile screen, which is considered inferior to the other models. For a 60", I would choose either E6500, or Panasonic U50, UT50, or ST50 depending upon budget.
tylerSC is offline
post #3 of 5 Old 09-04-2012, 05:33 PM - Thread Starter
Jelorian's Avatar
Thanks for your suggestions Tyler! I'll definitely start doing my research on the models you mentioned.
Jelorian is offline
post #4 of 5 Old 09-08-2012, 06:31 AM
tylerSC's Avatar
Quoted: 721 Post(s)
Liked: 166
Both the 60E530 and 60U50 are $999 right now, so I would look at those two. And HHG has been offering the LG 60PA5500 for $899, which is supposedly basically the same as the LG PA6500. Somethings you may want to look at.
tylerSC is offline
post #5 of 5 Old 09-10-2012, 01:02 AM
Straybeat's Avatar
We have had ours for about 3 weeks now and it is much better than our old 58B650. We loved the B650 and had complaints about it at all. The 3D is stunning to say the least. We even went out and rebought Transformers: Dark of the Moon just to watch it in 3D. The glare is highly overblown. We have 2 patio doors and 2 windows in our living room and haven't noticed the glare at all. It's there if you look for it, but if you just sit back and enjoy what's on you don't see it. It also had zero buzz, not even a hum out of it.
Straybeat is offline
Reply Plasma Flat Panel Great Found Deals!
