best 3d plasma available under $1000 - AVS Forum | Home Theater Discussions And Reviews
Old 12-16-2012, 12:00 AM - Thread Starter
blyonz04's Avatar
looking to upgrade my 42" lg plasma. Id like to have a new tv with the new features smart tv + 3d is a must ive never really tested these features so im not sure what tv is best. the biggest possible tv preferred id like to be around at least 50"-65" range the most bang for the buck deal. thanks!
blyonz04 is offline
Old 12-16-2012, 02:44 PM
Dierkdr's Avatar
Liked: 54
BIGGEST bang for your buck would doubtless be another LG Plasma - you should easily find a 60" LG Panel in the sub-$1000 range, but do not know whether you will find "smart" features or 3D at that Price/Size combination.
Would guess that the vast majority of 2012 LG Plasma owners are very happy with their sets, even though Reviewers have given the nod to Panasonic and/or Samsung plasmas as having the best overall PQ of 2012 models.
Amazon's web site usually does a good job at showing the Feature Set of various models (from the same manufacturer), or take a peek at the home pages of the manufacturers themselves.
There are a number of review sites - CNet and Consumer Reports (not free) are good starting points. (The CR web site provides much more Detail about the tested sets than their magazine does.)
Happy Hunting....
Dierkdr is offline
Old 12-16-2012, 03:52 PM - Thread Starter
blyonz04's Avatar
appreciate the reply im currently between the 55LM6700 Lg and the Samsung PN51E8000 51-Inch. both a little over 1000 but not bad
blyonz04 is offline
Old 12-16-2012, 04:02 PM
ambesolman's Avatar
Quoted: 1077 Post(s)
Liked: 901
If you have a newer bluray player with built-in apps and stuff, I wouldn't worry about that feature on your tv. I have a Samsung pn58c7000 and the 3d player (550 I think) that came with it. Thought I might use the smart stuff on the tv but never do since I stream movies with Vudu on the player.
ambesolman is offline
Old 12-16-2012, 04:25 PM
MechanicalMan's Avatar
I'm with ambesolman that it isn't worth paying more for something like the E8000, which just adds more features without any PQ improvement. You could buy a lower model and save money. FWIW, the 50ST50 can be had for $1,000 or less (and so can the 55UT50). It was $900 +tax through EPP, if it's still available (the 55" ST50 was $1,025 but sold out, last I checked). I would choose the ST50 myself, but if you prefer Samsung, then you should consider the E7000. Personally, there is no way that I wold buy the 55LM6700.
MechanicalMan is offline
Old 12-16-2012, 08:46 PM - Thread Starter
blyonz04's Avatar
is $997 a good deal on the samsung pn51e7000 thinking i might go with that one
blyonz04 is offline
Old 12-16-2012, 09:55 PM
Yes, AFAIK, that's as good as it gets right now for that TV (online). Again, I personally would rather buy the 50ST50 for the same price, but if you want a Samsung, then that's a good price.
Old 12-17-2012, 11:08 PM
jcrizzy's Avatar
Yeah I'm ordering the PN51e7000 for 2nd TV (i have PN58C7000 in the main living room and love the PQ).
I was getting this at Sears which *might still have a $200 Sears Gift Card. Plus using Sears card gives extra 5% off which should be nice price.
jcrizzy is offline
Old 12-18-2012, 01:01 PM
tylerSC's Avatar
Quoted: 725 Post(s)
Liked: 167
That is a very good price for this model, which has been priced several hundred dollars higher most of this year. It is a top tier model for Samsung plasma, and almost identical spec wise to to the E8000, minus a few bells and whistles such as built in camera. Best Buy also has the $999 price, and last week was still offering a $200 store gift card. Samsung or Panasonic would be the best choices for plasma in the upper end models, although LG can be a decent bang for the buck in the entry level 1080p category. But I would still choose Samsung or Panasonic for best overall pic quality.
tylerSC is offline
Old 12-27-2012, 07:28 PM
ScaryFatKidGT's Avatar
Ahhh 55UT50 or 50ST50 all the way
ScaryFatKidGT is offline
Old 01-06-2013, 06:00 PM - Thread Starter
blyonz04's Avatar
ended up going with a the 55lm9600 because i found a deal i couldnt pass up got it for around $1200 and sells for over 2 grand was a amazon warehouse open box couldnt pass it up smile.gif
blyonz04 is offline
