2012 Samsungs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-24-2013, 07:42 AM - Thread Starter
Brasic's Avatar
Working at a retailer, I figured I'd let you know that as of today, all 2012 UPP Samsung Models are officially not fixed anymore.
If you still want a high-end Sammy, now is the time to haggle if your only options are Big Box stores =P
Brasic is offline
post #2 of 8 Old 03-19-2013, 01:03 AM
DoTheEvolution's Avatar
Just got the Samsung PN60E7000 for a shade above $1,300!
DoTheEvolution is offline
post #3 of 8 Old 03-26-2013, 11:14 AM
jctrader's Avatar
Anyone looking for a really good looking ultra slim unit(only 1.24" thick) should seriously consider this deal http://www.bestbuy.com/site/Samsung+-+55%26%2334%3B+Class+-+LED+-+1080p+-+120Hz+-+Smart+-+3D+-+HDTV/4922189.p?id=1218580138823&skuId=4922189
It's only $1200. I just got the 50" for $1000 after waiting for months for the price to come down.
jctrader is offline
post #4 of 8 Old 03-28-2013, 11:54 AM
aman74's Avatar
You mean the price isn't fixed?
Which big box stores haggle?
aman74 is offline
post #5 of 8 Old 03-29-2013, 11:04 AM
indyfred's Avatar
Not a bad price. Except this is in a "Plasma Great Found Deals" thread and this is a LED. Wrong "Deals" section.
indyfred is offline
post #6 of 8 Old 03-29-2013, 11:13 AM
Ph8te's Avatar
Quoted: 4551 Post(s)
Liked: 3980
most WILL, but you need to go in there with knowledge of current pricing to back you up.....If you go in well armed then you should get a good deal...Since the pricing of the 2012 sets has been "unrestrained" there is room to work with.....All Samsungs are now "price fixed" for the most part, until samsung gives the OK to release that hold wink.gif ...now go out and make a deal with the information you have gained here
Ph8te is offline
post #7 of 8 Old 03-29-2013, 02:39 PM
aman74's Avatar
Thanks. I just hope I can find the models I'm looking for.
aman74 is offline
post #8 of 8 Old 04-02-2013, 01:31 PM
got pn60e7000, panasonic bmp-dpt 220 blu-ray player and yamaha yas-201 for $1850 total.
Reply Plasma Flat Panel Great Found Deals!
