Tv stand with mount - AVS Forum | Home Theater Discussions And Reviews
Old 07-21-2013, 03:59 PM - Thread Starter
gsf1010's Avatar
Hello
I am looking to buy the 65" VT60, but really need a tv stand with and adjustable mount. Can any of you recommend one? I am having a hard time finding one on the internet and the ones at Best Buy did not have an adjustable mount. Thank you.
gsf1010 is offline
Old 07-22-2013, 11:52 AM
Jay Mammoth's Avatar
Quoted: 30 Post(s)
Liked: 35
Originally Posted by gsf1010 View Post
Hello
http://www.walmart.com/ip/Palisade-3-in-1-TV-Stand-with-Mount-for-TVs-up-to-60/10843656
Jay Mammoth is offline
Old 07-23-2013, 08:56 PM
tubayj's Avatar
Frys has the innovex TB077GBM which I got.
Says up to 60 inch but holds my 65S64 like a champ prob can hold up to 70-80 if the panel is under 200lbs.
Originally was going to go with the walmart one but so happy I didn't.
For $50 extra the black glass looks awesome and more elegant. Can't go wrong. biggrin.gif
http://www.frys.com/product/7409785?site=sr:SEARCH:MAIN_RSLT_PG
tubayj is offline
Old 08-29-2013, 11:30 PM
jdmvette's Avatar
i found this thread because i was in the same boat. after doing some research i decided to go with the bell'o TPC2133.
This stand says it's rated up to 60" or 125lbs. I have just bought a 65" ZT which weighs 90~lbs. The stand is 52" at it's widest and the set is 59" so there will be around 3.5" overhang on each side. i don't believe there will be any issues with this since the weight won't be a factor.
You must also read the specs on your TV's bolt pattern to be sure the new mount is wide enough for it. some of the stand/mount combos i found would not go as wide as the mounting points on the ZT (684mm).
i already have a bell'o triple play for the 52" in the bedroom and admire it's design so this one will most likely be just as good.
jdmvette is offline
Old 09-05-2013, 09:42 PM
jdmvette's Avatar
the bello set came in yesterday and it looks great.
the tv is mounted as low as possible on the stand but it is a tad high for me. the stand angles the tv downward so that helps out.
i'll put up some pics of this combo later.
jdmvette is offline
