Panasonic TH-50PZ80U right half screen black left side screen multi color and blurry - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-08-2013, 09:12 PM - Thread Starter
kanetaker's Avatar
Hey guys,
First time posting been reading the forums for a while, I just recently had my panny start acting up in this last week or so. As you can see on the picture, the right side of the screen goes black while the other goes blurry and kind of a multi color. If I unplug it and leave it for a few hours it will go back to normal and work for a few more hours some times days, but always returns to this eventually. I opened the menu and it shows on the blurry side, so I'm wondering if the panel is going bad or if its a board inside? Any idea what could be up with it? Just wondering if its worth attempting to fix or if I should just go with a new set. Thanks for all the help.
kanetaker is offline
post #2 of 4 Old 09-09-2013, 11:21 AM
indyfred's Avatar
You would be better off putting this post in the "Plasma Flat Panel Displays" forum. You should be able to get some help in there.
But, you placed this post in the "Plasma Flat Panel Great Found Deals" forum. So, someone looking to find a "deal" on purchasing a plasma will see this, but general users to the Plasma Flat Panel forum may not.
indyfred is offline
post #3 of 4 Old 09-09-2013, 11:30 AM - Thread Starter
kanetaker's Avatar
Thanks for the response Indy, I sent to have this thread deleted last night, and reposted in the Flat Panel Displays forum. So far no responses, so we will see :/
post #4 of 4 Old 09-18-2013, 01:33 PM
tomwil's Avatar
Liked: 26
http://www.avsforum.com/t/1489791/panasonic-th-50pz80u-right-half-of-screen-black-left-side-blurry-and-multi-color
That which may be known of God is evident within man, for God has shown it to them, so that they are without excuse. (Romans 1:19-20)
tomwil is offline
Reply Plasma Flat Panel Great Found Deals!
