newbie gets panny 65vt60 BB open box/display for $1758 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-12-2014, 04:41 AM - Thread Starter
tailwagger60's Avatar
Thanks to everyone on this and other forums for teaching a newbie about HDTVs and how to buy one. I decided on the large panny plasma and wanted the comfort of buying from a large store for set-up, support and peace of mind. After missing the recent Amazon/BB deals on a new 65" for first $2000, then $2300, I started hunting for an open box/display on BB, Amazon Warehouse, Pacific Sales, Fryes, etc., in NorCal. I just purchased one for $1758 from BB. Here are some of the particulars.
1. Paid $1758 for a set that was built around April/May 2013 and displayed for many months in BB and in one previous owner's house.
2. 2600+ hours logged in Status4.
3. Purchased and returned late last year because customer said it was 'too dark' for his use.
4. Ran the Screen Swipe and it seemed pretty good, though being a newbie made it hard to know for sure. Had rep show me a bad TV screen swipe as comparison and I can say for sure the panny looked much better than the bad TV, but the black/white squares were not perfectly uniform, though they seemed very close to it.
5. Used my flashlight and did not see any obvious cracks. Rep showed me pixels with the flashlight and said they looked fine to him.
6. Did not run any color slides. Rep said he found the color excellent. The rep knew about this TV from when it was first manufactured and displayed in BB, then sold to 1st owner, and finally returned to store.
7. Listened and could not hear any noticeable fan noise.
    (a) Could this be one of the good fans made before Fall 2013 or should I be asking panny to do a foam fix? (Rep did not think there was ever a foam fix done, but was not sure.)
8. Listened and could not hear any panel buzzing.
9. All original accessories included (two 3D glasses, remote, directions)
10. A couple of small to medium scratches are present on the top left part of the frame (bezel?) (but not on the screen).
11. A couple of small to medium deep scratches are present on the pedestal (which is not an issue as I bought a wall mount)
12. BB lists the condition as "excellent". The rep was really knowledgeable and seemed really honest, which gave me a lot of comfort that it was a good fit and deal for me.
I then needed to complete the rest of the deal to have BB set the TV/audio up and running for this newbie.
13. $250 for Geek Squad TV delivery (52 miles), a (no articulation) Rocketfish Large Tilt Mount, and Geek Squad set up of TV on the mount. (Broken down as $150 for TV and $100 for Mount).
14. $500 for Denon DHTS-514 Soundbar (which is a ~16.7%, $100 discount).
15. $50 for Geek Squad to install the sound bar (so they get back $50 from the $100 discount).
16. $90 Panamax surge protector (also installed by Geek Squad).
17. BB rep threw in 3 free HDMI cables (retail 3 x $30/each), which is equivalent to a $90 discount.
18. Decided against extended warranty for now. I think I have 30 days or more to do it. Rep panned 3-yr. Costco ST plans and said BB was not doing "extended" warranties anymore, but rather, were doing their own warranty to run from Day 1 to avoid all the confusion on the differences between each insurer. BB warranty is $220 for 2 yrs. and $400 for 5 years. It is pricey, but according to rep, the best insurance out there. I will probably skip it and take my chances (while still getting some kind of coverage in Year 1 coverage from panny and Year 2 from VISA).
19. $206 CA tax.
TOTAL: $2,860.
I feel pretty good about the deal given my newbie status so I am hoping I did okay. Of course, the biggest thing is whether the TV is good, and I think it is. I would appreciate any comments (because I can obviously return it or even refuse delivery due before Feb 21.
Thanks.:)
tailwagger60 is offline
post #2 of 4 Old 02-22-2014, 05:14 PM - Thread Starter
BB Geek Squad delivered and installed my open box 65VT60 ($1758) yesterday. So far, all looks well. However, being a newbie, I am afraid I might not notice defects. For instance, the TV was built around April 2013, but I can barely hear the fan, so does that mean my fan is fine and not all of the early built TVs had fan problems? (Salesmen does not think a fan fix was done.) Most importantly, I do not see any "burn in" or "image retention". However, could a newbie not notice such problems? I am thrilled to have it.
post #3 of 4 Old 02-23-2014, 08:21 AM
eric3316's Avatar
Quoted: 839 Post(s)
Liked: 959
If you can't hear the fan or if it doesn't bother you, then who really cares if it has the fix or not? The whole point of the fix is to lessen the effect it has on your overall viewing. If it's not effecting you then it is not a problem.
If you want to check for IR, then you can run colored slides and if it is there you will find it. I suggest moving forward we continue this discussion in the dedicated VT60 thread...
eric3316 is offline
post #4 of 4 Old 02-24-2014, 01:59 AM - Thread Starter
Yes, sorry, I have moved forward in VT60 thread.
Reply Plasma Flat Panel Great Found Deals!
Panasonic Tc P65vt60 65 Inch 3d Smart Plasma Hdtv
