ACER H5360 720P 1280x720 2500 ANSI Lumens NVIDIA 3D Vision Ready Home Theater DLP Projector $349.99 w/ free shipping @ Newegg - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-21-2012, 09:35 PM - Thread Starter
Peteybob35's Avatar
Quoted: 13 Post(s)
Peteybob35 is offline
post #2 of 5 Old 11-22-2012, 10:36 AM
jamescam's Avatar
I know very little about projectors... Would this be good for the kids play room (occasional movie, playing video games)? There are 2 big windows with blinds in the room and it can get stuffy so brightness and loudness of the projector are important. Any other deals I should be looking at for such a thing?
I can hang the projector 12' back from the wall but there is a beam at ~6' back, how big can you project from only 6' back?
jamescam is offline
post #3 of 5 Old 11-23-2012, 09:32 AM
roknrol's Avatar
Quoted: 32 Post(s)
Liked: 38
This projector for $350 is a steal. It has a number of limitations, such as a limited zoom and throw ratio. Check projectorcentral's calculator if you have narrow mounting requirements. Otherwise, it's very portable, a light cannon for combating ambient light, and throws a very good picture for the price.
roknrol is offline
post #4 of 5 Old 01-05-2013, 09:38 PM
Paul Hamm's Avatar
I have this Projector it is pretty cool but the only thing is I can't get any external speakers to work on it if I play my xbox360 on it. Do you know of anyway I could get this to work?
Paul Hamm is offline
post #5 of 5 Old 01-07-2013, 06:53 AM
princepapa's Avatar
I would recommend the 2 year warranty on this one. My family has two and both of them developed problems (one problem was terminal) before 1500 hours.
For a good price, I would buy another, but I would never consider it without a good warranty,
Very bright though, and while it's kind of loud if it isn't on eco mode, anything you're watching will probably drown it out.
princepapa is offline
Reply Front Projectors Great Found Deals!
Acer H5360 3d Dlp Projector
