AMD A6-3500 2.1GHz Triple Core: $49.99 at Microcenter - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 07-18-2012, 08:51 PM - Thread Starter
ljo000's Avatar
This is the lowest I've seen this chip anywhere. $72 at Amazon and $79.99 at Newegg. Great price for a 65w APU with decent GFX. Link...
ljo000 is offline
post #2 of 9 Old 07-19-2012, 10:53 AM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Good price.
assassin is online now
post #3 of 9 Old 07-19-2012, 12:48 PM
Zon2020's Avatar
The A6 X4 3670K Black Edition 2.7GHz Quad Core is $89.99. Probably a more powerful chip with better graphics than the i3-2100 for the same price. Runs hotter, but that's about the only drawback I see.
Do you think the heat would be a problem in an ITX build?
BTW, they are now selling the G620 for $39.99 in addition to the G630 for $49.99.
Zon2020 is offline
post #4 of 9 Old 07-19-2012, 05:00 PM
utee05's Avatar
Quoted: 30 Post(s)
I am curious if this would be a better buy than getting a G620? I was initially going to get the G620 at MC to pair with an HD5670.
utee05 is offline
post #5 of 9 Old 07-19-2012, 05:36 PM
winterescape's Avatar
winterescape is offline
post #6 of 9 Old 07-19-2012, 05:52 PM
utee05's Avatar
Quoted: 30 Post(s)
Thanks for the link. I'll just stick with the G620. At the price (assuming I can find one) is a great deal for a cheap HTPC build.
utee05 is offline
post #7 of 9 Old 07-20-2012, 08:51 AM
ilovejedd's Avatar
Quoted: 76 Post(s)
Liked: 67
Good choice. The only value for Llano is the integrated GPU. If you're installing an HD 5670, the Pentium G620 is a better option.
ilovejedd is offline
post #8 of 9 Old 07-21-2012, 09:00 AM
Yes, in summary the integrated graphics are much stronger in the AMD part and the CPU is much stronger in the Intel part. I would question the need to add an additional graphics card to the Intel CPU unless you wanted 3D.
post #9 of 9 Old 07-22-2012, 08:52 PM
utee05's Avatar
Quoted: 30 Post(s)
The only reason I am adding an additional graphics card is cause I have it sitting in my closet and needs to be used. Might as well use it.
utee05 is offline
Reply Computers and Parts Great Found Deals!
