Hauppauge 1800 $9.99 free shipping - AVS Forum | Home Theater Discussions And Reviews
post #1 of 27 Old 02-06-2013, 01:12 PM - Thread Starter
macks's Avatar
Liked: 31
I didn't see anything about ebay in the TOS so here you go:
http://www.ebay.com/itm/Hauppauge-WinTV-HVR-1800-HDTV-Tuner-Capture-Card-PCI-e-/330874334624?pt=US_Video_Capture_TV_Tuner_Cards&hash=item4d09a5ada0
I bought one of these 3 or 4 months ago and it has worked great. Different seller but same product.
Please note: The 1800 is a single ATSC feed. For 10 bucks who cares though.
Edit: Updated link.
macks is offline
post #2 of 27 Old 02-09-2013, 08:29 AM
smac1221's Avatar
Would I be able to use this with a Comcast Card to receive my HBO and other paid channels or will I only be able to receive OTA broadcasts?
I would like to get rid of the Cable DVR and record some sporting events on the PC.
smac1221 is offline
post #3 of 27 Old 02-09-2013, 09:19 AM - Thread Starter
macks's Avatar
Liked: 31
OTA only. The cablecard tuners are all over $130 or so
smac1221 likes this.
macks is offline
post #4 of 27 Old 02-09-2013, 09:37 AM
bretski's Avatar
If I'm reading the description correctly, a cable connection would have to be split in order for it to tune clear QAM and analog channels?
bretski is offline
post #5 of 27 Old 02-09-2013, 09:52 AM
staknhalo's Avatar
Quoted: 383 Post(s)
Liked: 241
Yeah. The Hauppage 2250 is the only card I've ever come across that will do NTSC and QAM over the same coaxial input (USB combo tuners aside).
staknhalo is offline
post #6 of 27 Old 02-09-2013, 10:13 AM
bretski's Avatar
^ Thanks. I've been hemming and hawing over a 2250, but at $100+, haven't pulled the trigger. For $10, I'm willing to take a chance on this (and inserting a splitter)...
bretski is offline
post #7 of 27 Old 02-09-2013, 10:20 AM
staknhalo's Avatar
Quoted: 383 Post(s)
Liked: 241
I have a 2250. One coaxial, dual tuners of each type (ATSC, NTSC, QAM), and an FM tuner make it worth the cost IMO. This card here's is a great deal for $10.
post #8 of 27 Old 02-09-2013, 04:04 PM
Duke Broadway's Avatar
So this card has a tuner for ota channels, ane one tuner for cable channels? I am looking for a dual ota tuner so I can record one channel while watching another. If that is the case this isnt the tuner for me.........correct?
Duke Broadway is offline
post #9 of 27 Old 02-09-2013, 04:22 PM
bretski's Avatar
Correct. Keep an eye on Amazon for the Avermedia Duet. They've been coming and going for $49.99 as inventory is available:
http://www.amazon.com/AVerMedia-A188-HD-Duet-Windows/dp/B002HWRN9U
bretski is offline
post #10 of 27 Old 02-09-2013, 04:36 PM - Thread Starter
macks's Avatar
Liked: 31
That is correct. I ended up buying 2 since I have plenty of pcie slots.
macks is offline
post #11 of 27 Old 02-09-2013, 08:20 PM
Ahhh...so you just add a splitter before connection to the tuners. Very inexpensive way for 2 tuners.
post #12 of 27 Old 02-10-2013, 06:20 AM - Thread Starter
macks's Avatar
Liked: 31
Exactly, the dual tuner cards all have internal splitters.
macks is offline
post #13 of 27 Old 02-10-2013, 11:20 AM
smac1221's Avatar
I thought it could only record OTA by the answer to my post. However it has two tuners in it (only one active at a time) and it will record cable...just not the higher channesl like HBO and paid channels? Does this exclude HD Cable channels?
And of what value are the missing connectors on the back of the card. I see that for $15.95 you get the S-Video and RCA connectors on the card from another web site. They advertise free shipping, but when you get to the ordering process it calculates shipping for another $16.
smac1221 is offline
post #14 of 27 Old 02-11-2013, 05:39 AM
staknhalo's Avatar
Quoted: 383 Post(s)
Liked: 241
It will record over the air, analogue cable, and QAM digital cable. Things like HBO, or any other digital cable channel that is flagged/encrypted by your provider will not work. For that, you will need a CableCard tuner.
Basically if you take your cable coaxial and plug it directly into your HDTV (not cable box), whatever channels you get there you will be able to get with this card; plus the aforementioned OTA channels if you have an antenna.
post #15 of 27 Old 02-11-2013, 08:18 AM - Thread Starter
macks's Avatar
Liked: 31
Some companies are moving towards encrypting all channels. When this happens this card would be unable to pick up any channels. I imagine all cable providers will be doing this in the near future.
Just to clarify this card can receiver Analog(NTSC) and ATSC or QAM.
macks is offline
post #16 of 27 Old 02-11-2013, 11:24 AM
Doesnt look like this would fit in a silverstone MLO3, or am I mistaken. Full height vs half height?
post #17 of 27 Old 02-12-2013, 09:46 AM - Thread Starter
macks's Avatar
Liked: 31
For $10 buck I bought a second card and they both work fine. Shipping was very fast, also. I need a better antenna now though smile.gif.
macks is offline
post #18 of 27 Old 02-21-2013, 12:47 PM - Thread Starter
macks's Avatar
Liked: 31
Full height card.
I updated the first link with an updated $9.99 FS link.
I love cheap computer tuners. Works great under Linux, btw.
macks is offline
post #19 of 27 Old 02-22-2013, 10:23 AM
squeakybirnbaum's Avatar
Quoted: 26 Post(s)
Liked: 26
I have purchased a bunch of these for my HTPC's and ones that I've built for others. They have the strongest tuners of any that I've ever owned. I bought a motherboard with a bunch of PCI express slots so I could install 4 of these in my main HTPC. I love em.
squeakybirnbaum is offline
post #20 of 27 Old 02-22-2013, 11:43 AM
SlantNGo's Avatar
I just grabbed one. I haven't used a TV tuner in about five years, so I hope the technology has advanced significantly since then. Is there an easy way to switch between the analog tuner and the ATSC tuner (in WMC or WinTV) for this card?
SlantNGo is offline
post #21 of 27 Old 02-22-2013, 04:34 PM
Quoted: 26 Post(s)
Liked: 26
I have no idea about that, sorry. I only use them for OTA.
post #22 of 27 Old 02-22-2013, 05:51 PM - Thread Starter
macks's Avatar
Liked: 31
Analog is pretty much non-existent now. Chances are everything is ATSC for you and you don't even have to worry about it.
macks is offline
post #23 of 27 Old 02-23-2013, 10:44 AM
SlantNGo's Avatar
Right, but I was planning on hooking up the analog one to my cable box with an RF splitter (I don't have an HD cable box if you can believe it!) and the ATSC to an antenna. The only reason I'm interested in hooking it up to my cable box is to record cable channels, otherwise I'd be using the ATSC OTA feeds.
SlantNGo is offline
post #24 of 27 Old 02-23-2013, 10:55 AM - Thread Starter
macks's Avatar
Liked: 31
You should probably start a new thread in the normal htpc forum. Sorry I don't know the answer to the question.
macks is offline
post #25 of 27 Old 02-23-2013, 11:10 AM
SlantNGo's Avatar
No problem, I figure I'll try it out myself, and even if I can only get OTA ATSC to work, for 10 bucks who cares? smile.gif
SlantNGo is offline
post #26 of 27 Old 02-23-2013, 11:21 AM - Thread Starter
macks's Avatar
Liked: 31
The hauppauge 1800 is one of the best ATSC tuners that money can buy in my opinion, as long as you can live with it not being a dual tuner.
I'm kind of mad that OTA HD is better than what my cable company provides. Even Netflix is better than Time Warner HD though.
macks is offline
post #27 of 27 Old 02-23-2013, 11:59 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I just bought one. $9.99 and free shipping it's a no brainer.
Mfusick is offline
Reply Computers and Parts Great Found Deals!
