Jump Desktop VNC/RDP for Android - Free Today Only - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 05-02-2013, 08:11 AM - Thread Starter
bryansj's Avatar
Quoted: 1137 Post(s)
Liked: 561
http://www.amazon.com/gp/product/B0070DOHQS/
This is the exact program that I use to remotely connect to my home computers using my Android phone. Grab it for free today only.
bryansj is online now
post #2 of 16 Old 05-02-2013, 11:06 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Can you connect to more than one PC?
Sammy2 is online now
post #3 of 16 Old 05-02-2013, 11:16 AM - Thread Starter
bryansj's Avatar
Liked: 561
Yes. I have five listed in my app now. Three are virtual machines.
post #4 of 16 Old 05-02-2013, 12:39 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I need to check this out. Does it use RDP and you need a Pro machine or other hacked Win 7 machine?
post #5 of 16 Old 05-02-2013, 01:44 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Okay, I just snagged it so how to set it up not using a gmail account?
post #6 of 16 Old 05-02-2013, 02:18 PM - Thread Starter
bryansj's Avatar
Liked: 561
Do the manual setup. Forward your own port to 3389. You would then enter for host address your IP : port or dyndns:port such as sammy2.dyndns.org:3389 with logon the same as the one on your PC.
If you don't understand port forwarding then let me know.
post #7 of 16 Old 05-02-2013, 04:16 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
There's bots that search for that port and then use password crackers to get in. I had it set up for a bit on my HTPC but had to shut down that port. Of course I could use a stronger password as the one I had was simple for local network use.
post #8 of 16 Old 05-02-2013, 04:47 PM - Thread Starter
bryansj's Avatar
Liked: 561
Just forward some other port to 3389.
post #9 of 16 Old 05-02-2013, 05:04 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Fortunately I have a static IP address.. Or at least Charter hasn't changed it in as many years as I've had service with them..
post #10 of 16 Old 05-02-2013, 05:24 PM - Thread Starter
bryansj's Avatar
Liked: 561
Well, the app was free and you could just use it on your LAN if you didn't want to open any ports.
post #11 of 16 Old 05-11-2013, 12:23 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I did grab this when it was free and it shows up on my phone but it doesn't load when I load it from the phone..
post #12 of 16 Old 05-11-2013, 02:57 PM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
I grabbed it for my phone and kindle fire, and they both work fine. Maybe remove from your device and re-install, Amazon keeps it as an app you purchased so you shouldn't have a problem installing it to your phone again.
oman321 is offline
post #13 of 16 Old 05-12-2013, 08:16 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I got it installed. I just need to get it configured.
post #14 of 16 Old 05-12-2013, 09:28 AM - Thread Starter
bryansj's Avatar
Liked: 561
You need Windows running Pro or higher or hacked in RDP on the Home versions. Or you install VNC and use that instead.
http://support.jumpdesktop.com/entries/194620-setup-manual-configuration
post #15 of 16 Old 05-13-2013, 01:30 PM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
Connection type RDP
Domain name or external IP address as host , port number (as bryansj suggests I redirect a different one to 3389),
Windows user name, password
In like Flynn.
If your using it locally without a domain name you probably need the local IP address instead. Mine works fine with the domain name locally.
oman321 is offline
post #16 of 16 Old 05-23-2013, 09:07 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
BTW, I got this all configured using RDP and not the gmail login method.
Reply Computers and Parts Great Found Deals!
