BD players that play MKV files from DVD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-12-2014, 11:33 AM - Thread Starter
Carlos Martinez's Avatar
Quoted: 14 Post(s)
Can anyone tell me of BD players that can play MKV files burnt on DVD discs?
Until recently I have been backing up my Blu-ray library as mkv files, converted from the original discs for my personal use and my children's.
At first I used an LG BD-390 player, which seemed to play everything you three at it. But then things got difficult with 3D films, because the LG refused to play two-screen subtitles.
My first option for that was the WD TV media player, but soon I realized the WD does not accept external optical sources, only HDDs.
So I went looking again, and it seemed the Pioneer BDP-140 could be a likely replacement. Alternative firmware had to used, though, because it was a bit limited subtitle-wise "as is".
But later it proved also picky on what mkv files it did play.
My greatest problem in many modern BD players is Cinavia, which apparently blocks BD copies, even if for personal use.
What options do you suggest?
Carlos Martinez is offline
post #2 of 2 Old 03-12-2014, 03:56 PM
Super Moderator
teachsac's Avatar
Quoted: 861 Post(s)
Liked: 1397
Please use the help me choose a player thread. This sub forum is for player deals.
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
Closed Thread Blu-ray Player Great Found Deals!
