Face Audio F1200TS stereo amplifier - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 06-06-2012, 12:04 PM - Thread Starter
KevinH's Avatar
Quoted: 192 Post(s)
Liked: 71
HUGE PRICE DROP!...$1,350 retail
New Face Audio F1200TS stereo amp. Bought to use to power a couple of passive subs but never did. Going the powered sub route now. Specs via the Face Audio website:
F1200TS Product Description: What do you want in an amp? Breathtakingly clear, wide sound with zero distortion? Rugged, long-lasting reliability? Components that won't break a sweat under amp-kicking loads that would shut other equipment down? You want a lot! But that's okay because we have just what you're looking for: the Face Audio Titanium Series family of professional-grade amplifiers. Proven to be longer-lasting and more reliable than many higher-priced products, these amps keep their cool even when the action heats up, thanks to their "wind tunnel" cooling systems, high-efficiency voltage exchangers and a new filtering capacitor that guarantees excellent low-frequency control. Whether you need a smaller amp for a workplace or a workhorse for a large touring group, the Titanium Series has the right size amps to fit the bill . . . for a bill that won't blow you away.
Product Overview: Conventional 2 rack unit design....Unique cooling system provides long lasting performance....95% efficiency....Overheat, over-current, voltage and short circuit protection....Balanced XLR inputs....Speakon NL4MP ouputs....Auto muting on power up and shut down....Clip limiters on output....Switch-able stereo, parallel mono, and bridged modes....Product Specifications: 8ohm Stereo/740watts - Bridged/2240watts....4ohm Stereo/1100watts - Bridged/2700watts....2ohm Stereo/1350watts Nominal impedance of 20k Ohms on the inputs
Outputs: Speakon® NL4MP and binding post(wired in parallel)
Frequency Response: 20 Hz -- 20 KHz (+0dB/-2dB)
THD + N: 105 db
Damping factor:> 500 @ 100 Hz
Slew Rate:25 V/ms
Input Sensitivity: 1 V
Circuit: Class G
Power Input -- 110 V @ 60 Hz: NEMA 5-15p connector
Height: 3.5"
Width: 19"
Depth: 18.125"
Weight: 51 lbs.
Great amp for pro audio/live sound too. MSRP $1,350 Paypal +3%
-Kevin
JVC DLA-X550R projector/GIK Acoustic room treatments
Screen Innovations Black Diamond Zero Edge 1.4 110" 16:9
Marantz AV7702mkii pre-pro/Wyred4Sound 5-channel amp
Oppo BDP-105
JTR 3TX LCRs/Single8 HT-LP surrounds/2 RA Gamma21 master/slave pairs
KevinH is offline
Reply Audio Gear
