NEW unopened Sherwood Newcastle A965 / P965 - AVS Forum | Home Theater Discussions And Reviews
Old 06-19-2012, 10:02 AM - Thread Starter
gumbypoole's Avatar
These units are NEW and UNOPENED. Titanium finish. I feel most of you that would be interested in these already know about them, but...
A965 -
- 100Watts x 7 @ 8Ω, 20Hz~20kHz, 0.02% THD in Surround Mode(Full channel driven)
- 160Watts x 7 @ 4Ω, 20Hz~20kHz, 0.02% THD in Surround Mode(Full channel driven)
- 130W x 7 (1kHz, 0.02% THD)@8Ω / Only Channel
- 200W x 7 (1kHz, 0.02% THD)@4Ω / Only Channel
- Wide Range Amplifier Stage(WRAS) up to 200kHz
- Modular Design with 7 Separate Monoblock Amplifiers Built-on Individual PCB Cards
- 2 Separate Power Transformers(Toroidal)
- Heavy-Duty 5-Way Speaker Binding Posts
- Short Circuit Protection
- Thermal Overload Protection
- 12V DC Trigger Input
- Color-coded Terminals
- Gold Plated Input/Ourtput Jack
- Color Availability : Titanium
- Dimensions(WxHxD) : 440 x 196 x 450mm
- Weight(Net) : 32kg
P965 -
Specification
- DTS 96/24
- DTS-ES(Discrete/Matrix)
- DTS Decoder
- DTS Neo:6(Cinema/Music)
- Dolby Digital Ex
- Dolby Digital(AC-3) Decoder
- Dolby Headphone(1/2/3)
- Dolby Virtual Speaker(2/3/4/5 Speaker Layout)
- Cinema EQ
- Dolby Pro Logic Ⅱx Surround
- MPEG 2 Audio Multi-Channel Decoder
- 13 DSP Modes(Theater, Movie/Hall 1,2/Stadium/Church/4 Stereo/Club1,2/Arena 1,2/Game/Matrix)
- Field Upgradeable via RS-232 or USB
- 192kHz/24bit Digital Remastering for Greater Detail & Clarity (Analog Devices'AD1896)
- A/V Sync.Delay
- One Touch Automatic Speaker Setup
- Automatic Format Detection
- Moving Magnet Phono Input
- 7.1channel Direct Input with Composite and S-Video Input
- Bass Management of 7.1 Channel Direct Input for DVD-A and SACD
- 6 Rear Digital Inputs(2 Coaxial and 4 Optical) & Digital Output(1 Optical and 1 Coaxial)
- 24-Bit, 192kHz D to A converter, All Channels (Analog Devices'AD1852)
- 9 Preamp Outputs(Left, Center, Right, Left Surround, 2 Surround Back, Right Surround and 2-Subwoofer)
- Assignable Rear Digital Inputs(Via OSD Set-up)
- Front Panel A/V Input(Including S-Video and Optical/Digital In)
- 3 Component Video Inputs and 1 Component Video Output(HDTV Compatible)
- Video Upconversion (Composite -> S-Video -> Component)
- Pure Audio(Source Direct) for the Purest Stereo Reproduction
- Advanced Room 2 (Dedicated Remote Controller and A/V out including S-Video and digital coaxial audio)
- On-Screen Display(OSD) from Composite, S-Video and Component Video
- Preprogrammed & Learning 10-Device Remote Control with Large LCD
- Programable Input Labeling for Front Panel Display and OSD
- 5 Rear A/V Inputs and 2 Output including S-Video
Check the reviews online if you don't know these units. Especialy the amplifier - it has been compared to amplifiers selling for 5 or 6 times as much!
gumbypoole is offline
