Atlantic Technology IWTS-20e SR Inwall Spealers (pair) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-27-2012, 09:00 PM - Thread Starter
farfigngn's Avatar
THX-certified surround performance
The System 20 SR is called a surround speaker because that's what it does - it surrounds you with the environmental sounds of the scene taking place on the screen. No matter whether in Dolby Surround®, Dolby Digital®, DTS®, or any other format, the surround speakers are most often there to deliver non-localizable environmental sonic cues.
The horizontally mounted System 20e SR offers a unique combination of benefits. It delivers true Dipole surround performance, and yet, thanks to it minimum footprint design, fits easily into a standard 2 x 4 studded wall! Each System 20e SR consists of two sets of matched drivers * in essence it is two speaker systems. In Dipole mode these two systems operate "out of phase" with each other. The speaker's sound radiation pattern is similar to an infinity symbol, sweeping along the wall to each side. There's a distinct null or "dead zone" centered directly in front of the speaker which is in turn centered on the seating area. When properly placed and balanced, this creates a large, diffuse, non-localizable, and enveloping sound field that draws you into the action. Should you have an installation in which Dipole operation might be less than optimal, the speaker can easily be switched to Bipole operation.
Model System 20e SR
Drivers Dual 5 1/4 in. CCMG midranges w/Butyl rubber surrounds
Dual 3/4 in. natural silk dome tweeters w/Neodymium magnet and Ferrofluid cooling
Configuration Switchable Dipole or Bipole array
Frequency Response 80HZ - 20kHz +/-3dB
Sensitivity 87dB, 1 watt, 1 meter
Impedance 6 Ohms
Crossover point(s) 3.5kHz
Recommended power 50 - 200WRMS
Overall Dimensions 12 1/16x 15 5/8 x 3 3/4 in., 306 x 396 x 95mm
Cutout dimensions 11 x 14 3/8in., 279 x 365mm.
Installation kit IN-INST 20 SR required for all installations
Weight 9lbs.
****New in the box with wall mount brackets included. Left over from my install. A $1200 value. Dont miss out. Make an offer.
farfigngn is offline
post #2 of 2 Old 09-03-2012, 01:42 PM
chiworks's Avatar
Hi, what was the price please?
chiworks is offline
Reply Audio Gear
