Kef CI400 - AVS Forum | Home Theater Discussions And Reviews
Old 06-27-2012, 09:12 PM - Thread Starter
farfigngn's Avatar
Barely used and in mint condition with original boxes. KEF has taken a new style direction in custom installation with the Ci400 and the Ci400T.
Developed from the proven multi-award winning KHT2005, the innovative and stylish cast aluminium loudspeakers offer many advantages and benefits to the professional installer.
Using high-grade crossover components in conjunction with the Uni-Q® array contributes to hi-fi sound quality across the full frequency range, making the product ideal for both foreground and background music.
Choose the Ci400 with its adjustable ball joint and you have flexibility in positioning. Use it on its own base, mounted horizontally or vertically on walls, on ceilings or, using the heavy duty mounting bracket, attached to poles.
Decide on the Ci400T and you have the additional transformer mounted within the base, providing an option for use with 70/100v line systems.
Commercial installations requiring hi-fi performance will benefit from these stylish speakers.
Ci400 Features and Benefits
The 2-way Ci400 combines 50W power handling and 88dB sensitivity, for a maximum output of 104dB. A stylish cast aluminium reflex ported enclosure with 100mm (4”) polypropylene bass/mid cone and coincident mounted, twin neodymium magnet, 19mm (3⁄4”) aluminium dome, high-frequency unit. A choice of silver, soft black or pearl white finishes to suit architectural requirements.
Developed from the multi -award winning KHT2005, the Ci400 is an innovative loudspeaker offering many advantages and benefits to the professional installer.
The discrete, but aesthetically pleasing, cast aluminium enclosure houses a 100mm UNI-Q® driver array designed to provide ultra wide dispersion and uniformity of sound quality throughout the listening area – an essential attribute for commercial applications.
Unlike other ‘so - called’ coincident source loudspeakers, KEF’s revolutionary UNI-Q® technology positions a fully functioning moving coil tweeter at the exact acoustic centre of the mid/bass cone. The use of high-grade crossover componentsin conjunction with the UNI-Q® array contribute to hi-fi sound quality across the full
The adjustable ball joint between the loudspeaker cabinet and heavy duty mounting bracket provides flexibility in
positioning, enabling horizontal or vertical placement on walls, ceilings, in corners, or on shelves. An optional transformer is available, mounted within the bracket,
Despite the small size, it delivers extremely impressive performance; and with a choice of silver, soft black or pearl white finishes, to cater for a variety of interior décor schemes and architectural specifications, it is ideally suited to commercial installations such as bars, restaurants, leisure facilities or retail outlets.
Applications
The Ci Series Ci 400 is best suited for high quality music and speech reinforcement applications requiring hi-fi performance such as:
Multi Room systems
Home Theatre systems
Lounges, Bars, Boutiques
Boardrooms & Offices
Airports, Convention Centres, Hotels
Live Theatre/Concert Hall fill-in
Houses of Worship
Sports Arenas
Architectural Specifications
The Ci Series Ci 400 consists of:
1 X 19mm aluminium domeHF 100mm 'alu-skin' polypropylene cone with triple neo compound magnet system
Performance of the Ci 400 shall meet or exceed the following criteria: maximum output 104dB frequency response 80Hz - 27kHz continuous sensitivity shall be at least 86dB for 2.83V@1m. The driver impedance shall be 4ohms.
farfigngn is offline
