Klipsch Quintet II center - $50 (Midtown East) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 07-17-2012, 01:27 AM - Thread Starter
Purpose's Avatar
Selling used Quintet II center channel. (Image is stock image, only the center is being sold here). Speaker sounds great, no issues. Cabinet is in good condition.
CROSSOVER FREQUENCY: 4900Hz
DIMENSIONS: Center: 4.375" (11.11cm) x 12.125" (30.8cm) x 5.75" (14.61cm)
ENCLOSURE MATERIAL: Stone Mineral Compound
ENCLOSURE TYPE: Bass reflex via rear-mounted port
FINISHES: Black
FREQUENCY RESPONSE: Center: 120Hz-20kHz3dB
HIGH FREQUENCY HORN: 90x40 Tractrix Horn
NOMINAL IMPEDANCE: 8 ohms
POWER HANDLING: Center: 75 w (150 w peak)
SENSITIVITY: 90dB @ 1watt/1meter
TWEETER: K-104-KV 0.75" (1.91cm) Polymer dome compression driver
WEIGHT: Center: 6lbs
WOOFER: Center: Two K-1068-KV 3.5" (8.9cm) Poly cone
Willing to ship. shipping will be by fed ex ground and cost will be added.
Purpose is offline
Reply Audio Gear
