BFM Table Tuba (fully dressed) Dayton DSC205-4 - AVS Forum | Home Theater Discussions And Reviews
Old 07-20-2012, 05:20 PM - Thread Starter
Digital_Chris's Avatar
Hey there fellow members,
I've decided to unload my BFM table tuba. I made the cab out of 1/2" mdf and then wrapped it in pine followed by stain. The table came out great and I hate to let it go but I changed my setup around in my living room and recently it has been serving as a table only.
The driver has some use on it but no abuse, I am also including a brand new spare driver, the MCM 55-2421. I used the Dayton driver because the MCM was on backorder when I was building the cab.
The inside of the tuba was painted with one coat of flat black even thought the way I had it set up, the mouth was facing the corner so it couldn't be seen anyway, and the bottom is not painted or stained at all since that faced the floor.
Dimensions are 33" wide x 33" deep x 21" high.
Digital_Chris is offline
Old 09-21-2012, 06:36 PM
somenut1's Avatar
What are you running for power on it? Doing some reserch, still interested.
Fosgate 4125 power amp. B&K AV 6000, Fosgate Model Three processor. Fronts- Klipsch Hersey1 and Klipsch KLF-C7 center, Sides onkyo? Rears warfedale' Sapphire 88. Numark 2600 eq. Pioneer PDP- 50 inch, PS3.
somenut1 is offline
Old 09-22-2012, 03:41 AM - Thread Starter
I was using the $35 Foster plate amp that is unfortunately unavailable to purchase anymore. This cab does not need much power at all. The Foster plate amp only put out about 135 watts RMS I believe, and it was plenty.
Old 11-07-2012, 02:04 PM
blownrx7's Avatar
Hi Chris,
Can you please provide dimensions.
TIA
blownrx7 is offline
Old 11-07-2012, 03:32 PM - Thread Starter
