Onkyo TX-SR805 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 08-27-2012, 05:03 PM - Thread Starter
miker104's Avatar
Quoted: 24 Post(s)
Tx-sr805 comes with the calibration mic and power cable. I am the original owener and was used everyday There is a problem with the receiver, The audio does not work until it gets warmed up and has been this way for over a year(and Yes I stil used it everyday). I was told by local repair shop this is not the HDMI problem but sounds like a soilder joint needs to be fixed. Once the receiver is warm it works fine and if shut off an back on it will come right back on so I'm thinking this is the problem..
miker104 is offline
Reply Audio Gear
