XPA5 EMOTIVA AMP - AVS Forum | Home Theater Discussions And Reviews
Old 08-31-2012, 12:41 PM - Thread Starter
ditcin's Avatar
Quoted: 21 Post(s)
XPA-5
Five-Channel Power Amplifier
Condition: LIKE NEW (one year old) W/ORIGINAL PACKAGING/MANUAL
Modular channel design for increased separation and reliability.
Automatic 120/230 AC voltage detection and switching.
Switchable metering and status LEDs.
Fully protected from all fault conditions.
Soft start circuitry.
Advanced microprocessor operating system.
External trigger turn on.
Soft touch power switch.
4RU chassis w/ solid 15mm milled aluminum faceplate.
IEC power inlet.
Output topology: discrete Darlington with On Semi output devices.
Input topology: dual differential with cross coupled active current sources.
Input: balanced (XLR) and unbalanced (RCA), selectable.
Output: audiophile quality 5 way binding post.
Display type: dual color channel status indicators.
Specifications
Number of channels: 5
Signal to Noise Ratio:
1 watt: > 97 dB
Full power: >111 dB
Input impedance:
unbalanced: 23.5 kohms
balanced: 33 kohms
Transformer rating: 1,200VA
Secondary capacitance: 60,000uF
Output devices: 6 per channel
Topology: fully discrete, dual differential, high current, short signal path Class A/B
Power output (all channels driven):
300 watts RMS @ 4 ohm (0.1% THD)
200 watts RMS @ 8 ohm (0.1% THD)
Rated power bandwidth: 20 Hz to 20 kHz with less than .05 dB deviation at rated power
Broadband frequency response (-3 dB): 5Hz to 150kHz
Amplifier gain: 32 dB
Size:
unboxed: 17” wide x 7 3/4” high x 19” deep
boxed: 23 1/2" wide x 12" high x 24 3/4" deep
Weight: 72.6 lbs (83.8 lbs boxed)
Buyer pays for shipping, FEDEX
ditcin is offline
Old 09-03-2012, 06:54 PM
jhstl's Avatar
Payment sent. Can't wait to hear it
jhstl is offline
Old 09-03-2012, 08:55 PM - Thread Starter
ditcin's Avatar
Quoted: 21 Post(s)
Thanks for paying so quick. I will try to get this out tomorrow. I will let you know via your email with I do.
ditcin is offline
Emotiva Xpa 5 5 Channel Power Amplifier
