Onkyo TX-NR3007 - AVS Forum | Home Theater Discussions And Reviews
Old 09-15-2012, 09:28 AM - Thread Starter
ditcin's Avatar
Quoted: 21 Post(s)
ONKYO TX-NR3007 9.2 channels
2YRS OLD, ORIGINAL PACKAGING, REMOTE, MANUAL
EXCELLENT CONDITION
$600 Includes Fedex Ground Shipping within the continental U.S. PAYPAL PAMENT
If interested, contact me with your Zip code and I will send you the amount for shipping to add to the total.
Power Output
Front L/R
140 W + 140 W (8 ohms, 20 Hz–20 kHz,
0.05%, 2 channels driven, FTC)
Center
140 W (8 ohms, 20 Hz–20 kHz, 0.05%,
Surround L/R
Surround Back L/R
Front High/ Wide
Dynamic Power
320 W (3 ohms, 1 ch)
270 W (4 ohms, 1 ch)
160 W (8 ohms, 1 ch)
THD (Total Harmonic Distortion)
0.05% (Rated power)
Damping Factor
60 (Front, 1 kHz, 8 ohms)
Input Sensitivity and Impedance
200 mV/47 k-ohms (Line)
2.5 mV/47 k-ohms (Phone MM)
Output Level and Impedance
200 mV/470 ohms
Phono Overload
70 mV (MM, 1 kHz, 0.5%)
Frequency Response
5 Hz–100 kHz/+1 dB, -3 dB (Direct mode)
Tone Control
±10 dB, 50 Hz (Bass)
±10 dB, 20 kHz (Treble)
Signal-to-Noise Ratio
110 dB (Line, IHF-A)
Speaker Impedance
4 ohms–16 ohms or 6 ohms–16 ohms
Video Section
Input Sensitivity/Output Level and Impedance
Video
1 Vp-p/75 ohms (Component and S-Video Y)
0.7 Vp-p/75 ohms (Component PB/CB, PR/CR)
0.28 Vp-p/75 ohms (S-Video C)
1 Vp-p/75 ohms (Composite)
Component Video Frequency Response
5 Hz–100 MHz (-3 dB)
Tuner Section
Tuning Frequency Range
FM
87.5 MHz–107.9 MHz
AM
530 kHz–1,710 kHz
FM/AM/SIRIUS Preset Memory
40 stations
General
Power Supply
AC 120 V, 60 Hz
Power Consumption
11.6A
Dimensions (W x H x D)
17 1/8" x 7 13/16" x 18 1/4" br>(435 x 198.5 x 463.5 mm)
Weight
55.1 lbs. (25.0 kg)
ditcin is offline
Onkyo Tx Nr3007 140 Watts 9 2 Channel Av Surround Home Network Receiver Black
