ADA CINEMA RHAPSODY MACH IV HD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-28-2012, 07:35 AM
Sound&Life's Avatar
Quoted: 23 Post(s)
Hi,
I am selling my ADA Mach IV HD unit (it has HDMI 1.4 board inside).
It has had infrequent use in the the year that I've owned it. As you know, this pre/processor gets amazing reviews for audio.
It's for me the best HT processor I ever had or tested (Classe SSP800, TAG, Lexicon, Cary Audio, ...).
It's a first hand and I bought it end of last year (22/12/2011, so less than 1yr old) to the local distributor (Genesis Technologies France).
The unit is under warranty (so until 22/12/2013).
MSRP is 11240 € here in France (VAT in).
Please add freight charges.
Payement:
- Bank Wire Transfers without fees.
- Paypall: +3% to cover costs.
Copied from the web:
http://www.ada.net/products/ht/cinema_rhapsody_mach4b.php
The Cinema Rhapsody Mach IV-B is ADA's superior home theater controller/preamplifier. It features 8 HDMI inputs, 8 analog audio inputs, 8 digital audio input, and an 8 channel analog bypass input. There are also dual mirror HDMI outputs helping separate the Cinema Rhapsody Mach IV-B from other preamplifiers on the market. While similar in design to the Cinema Rhapsody Mach IV, the "B" version features balanced audio outputs.
The Cinema Rhapsody Mach IV-B decodes all the latest Dolby TrueHD, DTS-HD Audio Master and Multi-Channel PCM soundtracks found on Blu-ray DVDs. Just as HD video is noticeably better than regular DVD, these high-resolution (lossless) audio formats are dramatically better than regular 5.1 or 7.1 surround sound. You really can hear the difference and will never want to watch or listen to regular DVDs ever again. In a word, the home cinema as experienced on the Cinema Rhapsody Mach IV is fabulous.
The Cinema Rhapsody also has incredibly unique features that make it the only controller choice for many home theaters. In addition to featuring a simple to read and operate front panel control and its abundance of connection jacks, the Cinema Rhapsody Mach IV-B incorporates two bass crossovers, one in the DSP and one in the analog domain. This makes it possible for the Cinema Rhapsody Mach IV-B to work with full-range speakers, permitting them to play bass information while at the same time summing the bass of full-range channels with channels that are rolled off as well as the LFE (low frequency effects or ".1") channel. The subwoofer (speaker best designed to deliver bass) plays the bass from all channels simultaneously with the other speakers that are capable of delivering bass. With any other preamp, full range speakers would need to "roll-off" (not play bass) so that the subwoofer would play the bass. Not so with the Cinema Rhapsody Mach IV-B. Similar to providing a video loop facility so that one can incorporate the very best video processing, the Cinema Rhapsody makes it possible to incorporate the very best speakers into your system without compromising performance.
Dolby TrueHD & DTS HD Master Audio
Multi-Channel (192KHz/24 Bit) PCM Audio
Full 7.1 EX/ES, THX Ultra 2, Dolby Pro Logic IIx, DTS Neo 6
8 HDMI Inputs with HDMI Equalization Settings per input
2 (Dual) Mirror HDMI Outputs with HDMI Equalization Settings
Parametric Multi-Band Equalizer
8 Stereo Analog Audio Inputs
6 Digital Audio Coaxial Inputs
2 TOS-Link Optical Digital Audio Inputs
8 Channel DVD Audio/SACD Input With Bass Filters
8 Composite Video Inputs
8 S-Video Inputs
8 Component Video Inputs
Analog And Digital Audio Record Outputs (2nd Zone)
2 Main And 2 Record (2nd Zone) Composite Video Outputs
2 Main Component Video Outputs
Rear Panel Ethernet Connection (ADA Net)
2 Programmable Low Voltage Output Triggers
90-260Volts AC 50/60Hz 40 Watts
23 lbs 3.5"H x 19"W x 17.5"D
Sound&Life is offline
post #2 of 6 Old 10-02-2012, 04:48 AM
Sound&Life's Avatar
Quoted: 23 Post(s)
Hi,
I'm waiting for payement from Sakuma.
Regards
post #3 of 6 Old 10-02-2012, 03:57 PM
Sakuma's Avatar
Sakuma is offline
post #4 of 6 Old 10-03-2012, 12:52 AM
Sound&Life's Avatar
Quoted: 23 Post(s)
Got it. I'm going to call Paypal.
I have sent to you by email both the software and the invoice (warranty) of the unit.
Go back to you then with UPS news.
post #5 of 6 Old 10-03-2012, 03:55 AM
Sound&Life's Avatar
Quoted: 23 Post(s)
Got the payement and UPS removal scheduled.
post #6 of 6 Old 10-05-2012, 08:45 AM
Sound&Life's Avatar
Quoted: 23 Post(s)
ADA's removal by UPS done !!
Reply Audio Gear
