McIntosh MX151 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-28-2012, 07:21 PM - Thread Starter
mbovaird's Avatar
This is one of the best SSP's on the market. The sound and video reproduction is unparalleled.
I purchased this NEW in July and have had it on for less than 10 hours (I just don't watch a lot of movies). If you have a home theater, this McIntosh SSP is the best.
HDMI 1.4, 3D, more!
This is a MX151 (NOT an upgraded 150).
Price: $8500 including shipping anywhere in the CONUS.
Paypal users please add 3%.
Will accept payment by Cashiers Check or Paypal (+3%)
If interested, please contact:
Mike @ 941-932-0282 or mbovaird@me.com
The very best in music and film presentation - that's what you get with the MX151. Featuring the latest in HDMI technology with full support of 3D video pass-through, you'll see everything current Blu-ray discs™ have to offer. And when you combine the built-in Dolby® TrueHD and DTS-HD Master Audio™ decoding with the RoomPerfect™ room correction technology, which adjusts the audio signal to the specific acoustics of your space, the result is an enveloping audio experience that puts you in the center of the action.
Dual Zone feature allows you to play different media simultaneously in two separate rooms with independent program selection and control. The vast array of digital and analog inputs can be custom labeled for simplified system operation and matched in volume level for a smooth transition between sources. Assignable balance input and outputs, an analog phono section, bass and treble controls and optional processing up to 7.1 multi-channel using Dolby Pro Logic® IIx or DTS Neo:6 all enhance the two channel audio experience of the MX151.
The MX151's unprecedented flexibility allows custom system design and function for every environment. Control options include traditional IR-remote, web based GUI, and interfacing with all third party control systems. Audio options for up to 12 channels, multiple subwoofers, or bi-amping of speaker systems are built in.
RoomPerfect is a registered trademark and the RoomPerfect logo is a trademark of Lyngdorf Audio A/S.
CONNECTIVITY
INPUTS BALANCED
2 sets-Stereo
OUTPUTS BALANCED
7.1, + 2 AUX front channels
INPUTS UNBALANCED
8 Stereo + Moving Magnet Phono, 7.1 Input
OUTPUTS UNBALANCED
7.1 + 2 Aux front channels
DIGITAL INPUTS
4-coax, 4-optical, 1- AES/EBU Balanced
DIGITAL OUTPUTS
None
HDMI INPUTS
5 - With advanced HD audio processing, 3D video pass-through
HDMI OUTPUTS
One - Zone A, with advanced HD audio processing, 3D video pass-through
COMPONENT INPUTS
5
COMPONENT OUTPUTS
2
COMPOSITE INPUTS
2
COMPOSITE OUTPUTS
2
S-VIDEO INPUTS
2
S-VIDEO OUTPUTS
2
ADDITIONAL ZONE OUTPUTS
One Stereo: Zone B, Analog audio/video
MAX # OF AUDIO CHANNELS IN ZONE A
12
ADVANCED CONNECTIONS
Ethernet Web interface GUI, USB Firmware update
PROCESSING
ULTRA LOW DISTORTION (DSP BYPASS)
0.005%
DOLBY PROCESSING
True HD/Digital, EX/ProLogic IIx
DTS PROCESSING
HD Master & High Res. Audio/ES/96/24, Discrete & Matrix6.1, Neo:6
PURE STEREO DSP BYPASS MODE
Yes
VIDEO SCALING
None, transcode only to HDMI
CONTROL
THIRD PARTY CONTROL
RS232, Web IP, IR Input
TONE CONTROLS
Bass and Treble
OSD OVERLAY ON HDMI OUTPUT
Yes
INPUT-OUTPUT FORMAT INDICATORS
9 in and 9 out
CONTROL OF MCINTOSH SOURCES
Yes, wired with data cables
GENERAL SPECIFICATIONS
CHANNEL FORMATS
Stereo, 5.1, 7.1, Stereo Subwoofers
DSP ROOM CORRECTION
RoomPerfect, 1/12 octave
MICROPHONE AND STAND INCLUDED
Yes
NETWORK FEATURES
Ethernet Control and Setup
UNIQUE X-OVER FREQUENCY, EACH SPEAKER
Yes
SPECIAL FEATURES
Up to 121 input capability, Front Stereo Bi-amp + LFE Sub
APPLE COMPATIBILITY
COMPATIBLE WITH THE FOLLOWING DEVICES WITH THE LATEST APPLE OS INSTALLED.
IPHONE
None
IPOD
None
WEIGHTS & DIMENSIONS
DIMENSIONS (W X H X D)
17-1/2" (44.45cm) x 7-5/8" (19.37cm) (including feet) x 19-1/2" (49.53cm) (including front panel, knobs, rear panel connections and USB drive)
WEIGHT
31 lbs (14.06 kg)
SHIPPING WEIGHT
55 lbs (24.95 kg)
Mike
mbovaird is offline
post #2 of 4 Old 01-11-2013, 03:02 PM
stevethepa's Avatar
hello
i am interested in this unit
i have an old mx136
and a rotel amp1095 amp
i am looking to trade with cash if interested
please call steve waterman
5759939149
thanks
stevethepa is offline
post #3 of 4 Old 03-16-2013, 10:09 AM
marcmenowitz's Avatar
I will offer you 7500 which is dealer cost fair deal for a slightly used unit
marcmenowitz is offline
post #4 of 4 Old 03-16-2013, 10:09 AM
my email is mam@ara.ms
Reply Audio Gear
