Classe CT-2300 Amplifier - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-08-2013, 07:46 PM - Thread Starter
adidino's Avatar
Quoted: 362 Post(s)
Liked: 277
Selling my Classe CT-2300 2 Channel amplifier. In excellent condition and complete with all original packing, cables and accessories. When of the best 2 channel amplifiers in the market.
There are plenty reviews on this amp. Very clean and powerful.
Note: This amp is made in Canada not the made in CHINA version.
Will ship anywhere in the USA. Local pickup in NJ is ok.
Please feel free to contact me directly via email or phone with any questions. 973-388-0900. See my other listings for Classe CT-SSP processor and CT-M300 monoblock amp.
Specs
All tests un-weighted and 500kHz measurement bandwidth (except SNR).
Model CT-2300
Frequency response 1Hz – 80kHz, -3dB
Output power 300W rms into 8Ω (24.8 dBW)
600W rms into 4Ω (24.8 dBW)
Both channels driven
Harmonic Distortion 90dB below fundamental into 8Ω balanced / single ended
>90dB below fundamental into 4Ω balanced / single ended
Signal to Noise Ratio -116dB at peak output into 8Ω
Measurement Bandwidth: 22kHz
Output impedance 0.015Ω @ 1kHz
Rated power consumption 420W @ 1/8th power into 8Ω
Width (including faceplate) 19” (483mm)
Width (excluding faceplate) 17” (432mm)
Depth (excluding connectors) 18.625” (473mm)
Height 6.97” (177mm)
Gross weight 109lbs (49.5kg)
Net weight 89lbs (40.5kg)
Mains voltage Specified on rear panel
adidino is offline
Reply Audio Gear
