Classe CT-M300 Monoblock Amplifier - AVS Forum
post #1 of 2 Old 01-08-2013, 07:47 PM - Thread Starter
adidino's Avatar
Liked: 44
Selling my Classe CT-M300 Monoblock amplifier. In excellent condition and complete with all original packing, cables and accessories. There are plenty reviews on this amp. Very clean and powerful.
Note: This amp is made in Canada not the made in CHINA version.
Will ship anywhere in the USA. Local pickup in NJ is ok.
Please feel free to contact me directly via email or phone with any questions. 973-388-0900.
Specs
Model CT-M300
Frequency response 1Hz – 80kHz, -3dB
Output power 300W rms into 8Ω (24.8 dBW)
600W rms into 4Ω (24.8 dBW)
Harmonic Distortion 90dB below fundamental into 8Ω balanced / single ended
>90dB below fundamental into 4Ω balanced / single ended
Signal to Noise Ratio -116dB at peak output into 8Ω
Measurement Bandwidth: 22kHz
Output impedance 0.015Ω @ 1kHz
Rated power consumption 420W @ 1/8th power into 8Ω
Width (including faceplate) 19” (483mm)
Width (excluding faceplate) 17” (432mm)
Depth (excluding connectors) 18.625” (473mm)
Height 6.97” (177mm)
Gross weight 96lbs (43.5kg)
Net weight 76lbs (34.5kg)
Mains voltage Specified on rear panel
adidino is offline
post #2 of 2 Old 01-09-2013, 06:16 PM
thebland's Avatar
Quoted: 53 Post(s)
Liked: 88
Hey Tony,
All your great Classe' stuff is going... What are you moving on to? smile.gif
There are more than a handful of [op amps] that sound so good that most designers want to be using them as opposed to discreet transistors. Dave Reich, Theta 2009
thebland is offline
Reply Audio Gear
User Tag List
