Klipsch RS3 II Surround Speakers - Mint! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-30-2013, 11:33 AM - Thread Starter
airdough49's Avatar
Mint condition Klipsch RS3 II surround Speakers. Smoke free home, rarely used. These speakers are in perfect condition and sound great. Had to downsize my home theater room, so Im letting these go. Buyer pays actual shipping, or can pick up locally in San Diego, CA.
Description
Listen to music once on the Klipsch RS-3 II and you will never want to go back to anything else again. With a peak power handling capacity of 300 Watt, this Klipsch rear speaker gives you awesome performance every time. The Tractrix Horn of this Klipsch 300 Watt speaker enhances the efficiency and reduces the distortion, thus adding to the sound quality. The 90°x 60° coverage pattern of the Klipsch RS-3 delivers smooth and neutral output as well as realistic spatial imaging. The two-way construction of this Klipsch rear speaker gives a perfect surround sound effect. Whether you want diffused effects or direct output, the Wide Dispersion Surround Technology of this Klipsch 300 Watt speaker can give you all.
Key Features
Speaker Type Rear Speakers
Mounting Bookshelf
Construction 2-Way
Outdoor/Indoor Indoor
Technical Details
Peak Power Handling 300 W
Nominal Power 110 watt
Frequency Responses 61 Hz - 20 kHz
Impedance 8 ohm
Sensitivity 95 dB
Connectivity Wired
Design
Available Colors Black
Cabinet Finish Wooden
Woofer Material Polymer Composite
Dimension
Width 18.7 in.
Depth 7.4 in.
Woofer Size 6.5 in.
Tweeter Size 1 in.
Weight 12 lb.
airdough49 is offline
post #2 of 6 Old 02-13-2013, 06:41 PM
getmp3s's Avatar
how much are you asking for the pair of RS3's ?
getmp3s is offline
post #3 of 6 Old 03-13-2013, 04:22 PM - Thread Starter
airdough49's Avatar
Hi, never saw your post...if your still interested I am asking $250 for the pair.
Aaron
post #4 of 6 Old 03-31-2013, 05:59 AM
Savageite's Avatar
Are these still for sale??
Savageite is offline
post #5 of 6 Old 03-31-2013, 11:42 AM
Savageite's Avatar
Ok...How much are you asking again? Also I'm in Maryland.
post #6 of 6 Old 03-31-2013, 01:10 PM - Thread Starter
airdough49's Avatar
Asking $250 for the pair
Reply Audio Gear
