FS; Klipsch RB 3 Bookshelf Speakers. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-31-2013, 08:58 PM - Thread Starter
GIXX1300's Avatar
These are in like new condition.No scratches dents etc.Grills are intact.Used as rear surrounds so these have never been pushed hard.These are the original Reference RB 3s.
FREQUENCY RESPONSE: 52Hz-20kHz±3dB
SENSITIVITY: 94dB @ 1watt/1meter
POWER HANDLING: 100 watts maximum continuous (400 watts peak)
NOMINAL IMPEDANCE: 8 ohms
ENCLOSURE TYPE: Bass reflex via rear-mounted port
DRIVE COMPONENTS: Two-way system using one 1" (2.54cm) magnetically shielded, titanium dome compression driver tweeter with a 5" (12.7cm) square 90°x60° Tractrix® Horn and one 6.5" (16.5cm) magnetically shielded, aluminum cone woofer
TWEETER: K-121-KB 1" (2.54cm) Titanium dome compression driver
HIGH FREQUENCY HORN: 5" square 90°x60° Tractrix® Horn
HIGH FREQUENCY CROSSOVER: 2600Hz
WOOFER: K-1081-SB 6.5" (16.51cm) Cerametallic® cone / cast polymer frame
DIMENSIONS (H x W x D): 15" (38.6cm) x 7.68" (19.7cm) x 9" (23.04cm)
WEIGHT: 15 lbs. (6.8kg)
ENCLOSURE MATERIAL: Medium density fiberboard construction (MDF)
FINISH Black wood veneer
Asking $325 Shipped obo.
Paypal accepted
GIXX1300 is offline
Reply Audio Gear
