Onkyo TX-NR3009 1 Month Old - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-09-2013, 07:03 PM - Thread Starter
jslaw81's Avatar
Only one month old. Purchased from Frys Electronics. I have the receipt. Its in mint/new condition. I just have the receiver, powercord, and audyssey mic. Unfortunately I don't have the box and remote. I'd pack it just like as if it was in the onkyo box. Any universal remote will work with it. I used a Logitech Harmony 1100 with it. Call or text 678-602-7976.
Detailed item info
Product Information
Enjoy clear surround sound with the Onkyo TX NR3009, a 9.2 channel network A/V receiver that is ideal for your home theater system. Featuring 8 HDMI inputs, this Onkyo receiver offers plenty of connectivity options for all your high-definition sources. For an amazing, high-definition sound output, the Onkyo TX NR3009 equips Dolby and Audyssey. Using the USB input, you can connect this Onkyo receiver to your flash drives and digital audio players. So, get this 9.2 channel network A/V receiver for a thrilling viewing experience.
Product Identifiers
Brand Onkyo
Model NR3009
Family Line Onkyo TX
Product Type Home Theater Receivers
MPN TXNR3009
UPC 0751398010279, 751398010279, 751398010576
Key Features
Channels 9.2
Output Power 200 Watt
Amplifier Output Details 140 Watt - 8 Ohm - 20 - 20000 Hz - THD 0.05% - 9 channel(s) ( surround ), 200 Watt - 6 Ohm - at 1 kHz - THD 1.0% - 9 channel(s) ( surround )
Surround Sound Effects Neural Surround, Theater-Dimensional Virtual Surround
Sound Output Type DTS
HDMI Yes
3D Ready Yes
Built-in Decoders DTS 96/24, DTS Express, DTS-ES Discrete 6.1, DTS-ES Matrix 6.1, DTS-HD High Resolution, DTS-HD Master Audio, Dolby Digital EX, Dolby Digital Plus, Dolby Pro Logic IIz, Dolby TrueHD, THX Cinema, THX Ultra 2
Equalizer Included Yes
Equalizer Band Qty 7 bands
Receiver Tuner Type Digital
Receiver Tuner Bands AM/FM
Response Bandwidth 5 - 100000 Hz
Connectivity
Coaxial Digital Input Yes
Optical Digital Input Yes
Headphone Jack Yes
Miscellaneous
Remote Control Type Universal remote control
THX certified Yes
Bass Control Yes
Included Accessories Auto calibration microphone
Dimensions
Height 7.83 in.
Width 17.13 in.
Weight 55.12 lb.
jslaw81 is offline
post #2 of 2 Old 02-09-2013, 07:03 PM - Thread Starter
jslaw81's Avatar
I'm in the Atlanta GA area. Local pickup is welcomed.
jslaw81 is offline
Reply Audio Gear
Onkyo Tx Nr3009
