Snell QBx 20 Bookshelf Speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 02-10-2013, 12:49 AM - Thread Starter
mrdot's Avatar
For sale is a pair of Snell QBx 20 bookshelf speakers in cherry finish. This speaker was named an editor's choice by the Absolute Sound back in the early 2000s. These come in a bi-amp / bi-wire configuration, and also feature a boundary switch for placement in cabinets or close to other reflective surfaces.
Original MSRP was around $800, and I would like to get $300 for them. This price is VERY flexible. All offers will be considered!
The speakers sound great, but do exhibit some minor cosmetic damage, primarily some scrapes and bumps, as shown in the pictures.
Please contact me if you have any questions or would like more information.
Thanks for looking.
SPECS: Frequency Response: (±3dB)65Hz--20kHz, -6dB @ 55Hz Recommended Amplifier Power: 15--150 watts (above 80Hz) Nominal Impedance: 6 ohms Sensitivity (2.83v at 1m): 88dB SPL Tweeter (video-shielded): 1-inch (25mm) black-anodized aluminum dome with neodymium magnet structure and multi-finned aluminum heatsink Bass Unit (video--shielded): 6 1/2-inch (165mm) polymer chassis, HDA cone and rubber surround Cabinet Construction: 3/4-inch MDF walls Composite Baffle Construction: 5/8-inch high density fiberboard,high loss damping compound,and 5/8-inch MDF Grille: Black cloth, unique butterfly recess Dimensions (HxWxD): 81/2 x 14 x 10 inches 21.6 x 35.6 x 25.5cm
mrdot is offline
Reply Audio Gear
