Sonance Sub 8-100 new in box - AVS | Home Theater Discussions And Reviews
post #1 of 2 Old 02-16-2013, 04:37 PM - Thread Starter
jslaw81's Avatar
new in box Sonance Sub8-100. make me an offer. 678-602-7976 call or text
The SUB 8-100 cabinet subwoofer has an 8? (203mm) anodized aluminum cone woofer with extra long voice coil for low distortion at high outputs. The sealed enclosure is well braced and the flush-mounted 100 watt amplifier and front-mounted controls allow installation in tight spaces.
SPECIFICATIONS
Woofer8" (203mm) anodized aluminum cone, rubber surroundFrequency Response35Hz x 250Hz ?3dBAmplifier100 wattsInputsLine-level and speaker-levelOutputsHigh-pass filtered line-level and speaker-levelAdjustmentsFront-accessible level, crossover, phone and bypassGrilleBlack clothCabinet FinishHigh-gloss blackAvailable Options230V versionDimensions (WxHxD)12" x 14" x 12" (305mm x 355mm x 305mm)Shipping Weight40 lbs (18 kg) each
jslaw81 is offline
post #2 of 2 Old 02-16-2013, 04:41 PM - Thread Starter
jslaw81's Avatar
I'm in the Atlanta, GA area.
jslaw81 is offline
Reply Audio Gear
