Denon AV Surround Receiver AVR-1911 (3D) - AVS Forum
post #1 of 3 Old 02-20-2013, 08:06 AM - Thread Starter
walke108's Avatar
Liked: 25
Used Denon AVR-1911 7.1 A/V Receiver-fully functional. I am selling because I just upgraded to a newer model. Included with the receiver is the remote control, Audyssey Calibration Microphone, FM Antenna, and original Owner's Manual. I am the sole and original owner. System is in great cosmetic and operating condition. Will answer any questions or send additional pictures upon request. MSRP was $579.00.
Denon AVR-1911 7.1-Channel A/V Receiver
Support for latest high-definition audio and video formats
Cutting-edge audio technologies for exceptional surround sound
4 HDMI inputs for added connectivity
HDMI 1.4a for compatibility with 3D media
HD radio and iPod/iPhone Direct Connectivity
Equal power amplifier design gives a more faithful reproduction of the original sound.
View larger.
A full range of inputs support all the latest formats, including HDMI 1.4a for 3D media.
View larger.
Premium Audio Technologies for Superb Surround Sound
Fully compatible with the latest HD audio formats, the Denon AVR-1911 7.1-Channel A/V Receiver provides a powerful, theater-quality surround-sound experience. It ensures maximum audio performance with multiple cutting-edge technologies:
Equal Power Amp Design : Each of the AVR-1911's seven 90-watt channels is powered by its own, discrete circuit. This allows the receiver to reproduce the original sound more faithfully than conventional models, which use integrated circuits.
High-Definition Audio Support : The AVR-1911 features support for the latest Blu-Ray high-resolution audio formats, including Dolby TrueHD and DTS-HD Master Audio. These formats play back sound with exceptional fidelity, providing you with a more realistic listening experience.
Dolby Pro Logic IIz : Providing two additional height channels, this feature adds a vertical dimension to the soundstage, and a more immersive surround-sound experience.
Audyssey MultEQ Support : Audyssey technology helps create an optimal acoustic profile for your home theater. Using a microphone, Audyssey MultEQ measures sound levels and adjusts speaker configuration accordingly, making setup fast and easy.
Full HD Support and Up-Scaling to 1080p
With four HDMI inputs, the AVR-1911 allows you to route multiple high-definition devices--like game consoles and Blu-Ray players--to your TV. The receiver also upscales standard-definition video inputs to a 1080p HD signal. You'll be able to enjoy older media, such as VCR and DVD, in richer detail. It also allows you to connect all of your devices to your TV with a single HDMI cable, reducing cable clutter.
Vivid 3D Visuals with HDMI 1.4a
The AVR-1911 comes equipped with HDMI 1.4a, allowing you to make the most of several premium video features:
3D Pass-Through : With the advent of 3D media, it is important to own a receiver that recognizes 3D video signals. The AVR-1911 is able to pass through 3D signals from your Blu-Ray player, ensuring that the 3D effect doesn't get lost in translation. It also recognizes signals from 3D television broadcasts.
Audio Return Channel : HDMI 1.4a also features an Audio Return Channel, which allows both audio and video content to be sent through a single HDMI cable. This eliminates the need for a separate audio cable running from your TV to the receiver--only a single HDMI cable is needed.
Deep Color and x.v.Color Support : The AVR-1911 also supports Deep Color and x.v.Color schemes, which can display a larger color range than standard-definition schemes. The result is a more lifelike, vibrant picture.
HD Radio and iPod Connectivity
Equipped with an HD Radio, the AVR-1911 actively converts analog radio signals to digital, greatly improving the clarity of both AM and FM broadcasts. The receiver also features iPod and iPhone Direct Connectivity, allowing you to stream your music via a USB cable. A compressed audio restorer guarantees that MP3 playback is crisp and clear.
Ergonomic Design Promotes Easy Control
With its programmable functions and intuitive button layout, the AVR-1911 is designed to maximize ease of use. The front panel is smartly organized, featuring clearly-labeled buttons and onboard controls for volume and source. In addition, its on-screen display provides quick information about your system's settings.
The AVR-1911's remote can sync with other entertainment devices in your home theater, eliminating the need for multiple remote controls. It can also be easily programmed with macro functions, giving you more flexibility in controlling your home theater.
walke108 is offline
post #2 of 3 Old 02-20-2013, 04:11 PM
santiagodraco's Avatar
I am interested in buying this (for a friend). Please send me your name and number and I'll have her call you directly. This is what I've been pushing her to buy smile.gif
thanks,
Keith Knostman
512-670-8082
santiagodraco is offline
post #3 of 3 Old 02-21-2013, 06:57 PM - Thread Starter
walke108's Avatar
Liked: 25
thanks,
Keith Knostman
512-670-8082
Thanks Keith, I sent you a PM with my info.
walke108 is offline
Reply Audio Gear
Denon Avr 1911 Receiver
User Tag List
