Klipsch WC-24 Center MINT - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 02-23-2013, 10:33 PM - Thread Starter
Purpose's Avatar
From NYC
http://newyork.craigslist.org/mnh/ele/3639504164.html
Selling lightly used, mint condition WC-24 Center. Spent 100% of time inside fitted cabinet. Drivers in perfect condition, never stressed. Powered with good quality AVR. No nicks, scratches or blemishes on speaker cabinet. Pictures attached.
From Klipsch Website:
CROSSOVER FREQUENCY: 2500Hz
DEPTH: 6.5" (16.5cm)
ENCLOSURE MATERIAL: MDF
ENCLOSURE TYPE: Bass-reflex via dual rear-firing ports
FINISHES: Furniture-grade wood veneer available in cabernet or espresso
FREQUENCY RESPONSE: 85Hz-23kHz +/-3dB
HEIGHT: 6.5" (16.5cm)
HIGH FREQUENCY DRIVERS: 1" (2.5cm) titanium diaphragm compression driver mated to a 4.5" 80 x 80 round Tractrix(r) horn
LOW FREQUENCY DRIVERS: Dual 4.5" (11.4cm) high-output, fiberglass cone woofers
LOW FREQUENCY EXTENSION: 65Hz
NOMINAL IMPEDANCE: 8 ohms
POWER HANDLING: 90W continuous / 300W peak
RECOMMENDED AMPLIFIER POWER: 100W
SENSITIVITY: 94.5dB
WEIGHT: 11 lbs
WIDTH: 18" (45.7cm)
Purpose is offline
Reply Audio Gear
