Sony STR-V333ES Receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 02-24-2013, 06:00 PM - Thread Starter
NatasNJ's Avatar
For sale my used Sony V333ES Receiver, remote, and I think original Box. Will ship for Actual Shipping costs.
Product Information
Performance, flexibility, and value! Living up to the ES name, the STR-V333ES combines audiophile-pleasing design (rigid frame-and-beam construction, dual cast aluminum heat sinks, etc.) and oversized "guts" (filter capacitors, power supply, and output transistors) for stunning music and home theater performance.For mind-blowing 5.1-channel realism, you get 24-bit Dolby Digital and DTS decoding. Dual 32-bit processors deliver Sony's exclusive Digital Cinema Sound modes - you'll hear movie soundtracks the way producers and directors intended! And with 110 full-bandwidth-rated ES watts x 5, you can be sure all your speakers have plenty of power for maximum home theater impact.A vast array of digital and analog inputs (including 5 S-video inputs, 5 digital inputs, and a 5.1-channel input) accommodates all your A/V components. Sony's dual-room/dual source feature lets you enjoy one source in your main listening room while simultaneously passing the signal from another stereo source (CD, MD, etc.) to a shelf system, amp, or powered speakers in another room. You even get a stereo "analog direct" mode for bypassing DSP - great for high-resolution sources like SACD!
Product Identifiers
Brand Sony
Model V333ES
Family Line Sony STR
Product Type Home Theater Receivers
MPN STR-V333ES, STRV333ES
UPC 0027242571372
Key Features
Channels 5.1
Output Power 550 Watt
Amplifier Output Details 110 Watt - 8 Ohm - 20 - 20000 Hz - THD 0.05% - 1 channel(s) ( center ), 110 Watt - 8 Ohm - 20 - 20000 Hz - THD 0.05% - 2 channel(s) ( front ), 110 Watt - 8 Ohm - 20 - 20000 Hz - THD 0.05% - 2 channel(s) ( rear )
Surround Sound Effects Digital Cinema Sound Virtual 3D, VMAx virtual surround sound
Sound Output Type Surround Sound
HDMI No
Built-in Decoders DTS, Dolby Digital, Dolby Pro Logic
Receiver Tuner Type Digital
Receiver Tuner Bands AM/FM
Response Bandwidth 20 - 20000 Hz
Connectivity
Connectors Type 1 X AM Tuner Antenna input - rear, 1 X Composite (Video) output - rear, 1 X Digital Coaxial input - rear, 1 X Digital Optical output - rear, 1 X FM Tuner Antenna input - rear, 1 X Headphones output - front, 1 X Multichannel Analog Audio input - rear, 1 X Multichannel Analog Audio output - rear, 1 X RCA (2 Audio Channels) input - front, 1 X S-Video input - front, 2 X RCA (2 Audio Channels) output - rear, 3 X Analog Audio output - rear, 3 X S-Video output - rear, 4 X Analog Audio input - rear, 4 X Digital Optical input - rear, 4 X RCA (2 Audio Channels) input - rear, 4 X S-Video input - rear
Miscellaneous
Color Black
Remote Control Type Programmable remote control
Built-in Display Type Fluorescent
Dimensions
Height 6.81 in.
Width 16.93 in.
Weight 35.27 lb.
NatasNJ is offline
Reply Audio Gear
