Martin Logan Depth i subwoofer mint/new condition - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 03-03-2013, 04:24 AM - Thread Starter
jslaw81's Avatar
Purchased a couple months ago from an authorized dealer. A magnolia design center. It is in mint/new condition. I have the box and everything it came with. Local pickup only. Would consider shipping. I'm in the Atlanta,GA area. Call or text 678-602-7976
Frequency Response
20–120 Hz ±3dB; Anechoic through LFE effects input
Low Pass Filter Frequency
30, 35, 45, 55, 65, 80Hz
High Pass Filter Frequency
Bypass, 40Hz, 70Hz
Low Frequency Transducer
Three 8" (20.3cm) high excursion, aluminum cone with extended throw drive assembly, sealed non-resonant asymmetrical chamber format
Amplifier
350W (at less than 0.5% THD)
900W (peak)
Impedance
Line level RCA: 20,000 Ohms. Compatible with 4, 6, or 8 Ohm rated amplifiers.
Audio Controls
±10dB at 25Hz
Inputs
Left/Right RCA Line Level, RCA LFE, Speaker Level
Power Draw
Max: 300 Watts
Idle: 15 Watts
Standby: 10 Watts
Weight
70 lbs. (31.8 kg)
Dimensions
17.9" × 17.1" × 16.5"
(45.4cm × 43.5cm × 41.8cm)
jslaw81 is offline
Reply Audio Gear
