Stewart Firehawk 102" Screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 04-07-2013, 03:09 PM - Thread Starter
meckanik's Avatar
This is a Stewart FireHawk projection screen I purchased used about two years ago. The screen is in excellent condition with the exception of three hand-sized spots that are slightly more reflective than the rest of the screen.
After I purchased the screen I used a heat gun to speed up the removal of the wrinkles in the screen - this caused the aforementioned bright spots. The end result is that if you are looking for them you will see three oval areas that are slightly brighter. If you don't know to look you probably won't see them but I want to be forthright that the screen is not in perfect condition.
I'm pricing the screen at about half of what I payed for it. I feel this is a great deal considering the low impact of the blemish.
Not sure sure about shipping this because of the length of the lower frame pieces. I can look into it if someone is interested.
-Jeff
meckanik is offline
Reply Audio Gear
