TC Sounds LMS Ultra 5400 18" DVC Subwoofer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-07-2013, 08:52 PM - Thread Starter
hillikja's Avatar
New in box, unused mint condition, $650 call or text ####(three one four)-596-6894######
I'm located in St. Louis, Missouri
Designed to be absolutely precise, and absolutely loud is the LMS Ultra 5400. The TC Sounds flagship transducer is the most linear lowest distortion highest displacement low frequency driver in the world. Nothing, and we mean nothing, will outperform this driver for low-end displacement, ultra-low distortion, or SPL. The TC Sounds LMS Ultra 5400 is used in some of the best recording studios and high-end audio systems.
PRODUCT SPECIFICATIONS
Power Handling (RMS) 2000 Watts
Power Handling (max) 8,000 Watts
Impedance 2+2 ohms
Frequency Response 15 to 150 Hz
Sensitivity 89.7 dB 1W/1m
Voice Coil Diameter 4"
Magnet Weight 525 oz.
THIELE-SMALL PARAMETERS
Resonant Frequency (Fs) 20.5 Hz
DC Resistance (Re) 3.78 ohms
Voice Coil Inductance (Le) 1.96 mH
Mechanical Q (Qms) 7.60
Electromagnetic Q (Qes) 0.34
Total Q (Qts) 0.33
Compliance Equivalent Volume (Vas) 8.50 ft.³
Mechanical Compliance of Suspension (Cms) 0.12 mm/N
BL Product (BL) 26.8 Tm
Diaphragm Mass Inc. Airload (Mms) 501.3g
Maximum Linear Excursion (Xmax) 33.66 mm
MATERIALS OF CONSTRUCTION
Cone Material Aluminum
Voice Coil Former Stainless Steel
Basket / Frame Material Cast Aluminum
Magnet Material Ferrite
MOUNTING INFORMATION
Overall Outside Diameter 18.52"
Baffle Cutout Diameter 16.83"
Depth 11.54"
# Mounting Holes 8
hillikja is offline
post #2 of 5 Old 04-08-2013, 05:32 AM
Gorilla83's Avatar
Quoted: 378 Post(s)
Liked: 524
Good deal! Where are you located for those interested?
Gorilla83 is offline
post #3 of 5 Old 04-12-2013, 12:40 PM - Thread Starter
hillikja's Avatar
St. Louis, Missouri
hillikja is offline
post #4 of 5 Old 05-14-2013, 09:42 PM
ht-core's Avatar
looking for one but im in Hawaii.
ht-core is offline
post #5 of 5 Old 09-08-2013, 09:35 PM
Archaea's Avatar
Quoted: 3086 Post(s)
Liked: 2715
Jason,
Do you still have this thing? I didn't now you had it when I picked up the cabs.
Archaea is offline
Reply Audio Gear
