Martin Logan Theos Pair Zebrawood - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 04-09-2013, 03:10 PM - Thread Starter
jslaw81's Avatar
New open box pair of Martin Logan Theos towers in zebrawood. Full warranty. never used. call or text 678-602-7976
Frequency Response43?23,000 Hz ?3dBHorizontal Dispersion30?Vertical Dispersion44" (112cm) line sourceHigh Frequency TransducerXStat? CLS? electrostatic transducer? Panel Dimensions44" ? 9.2" (111.8 ? 23.4cm)? Radiating Area405 in2?(2,616 cm2)Low Frequency Transducer8" (20.3cm) cast basket, high excursion, aluminum cone with extended throw drive assembly, non-resonance asymmetrical chamber format, down-firing bass reflex port.Sensitivity90 dB/2.83 volts/meterImpedance4 Ohms, 0.8 at 20kHz. Compatible with 4, 6, or 8 Ohm rated amplifiers.Recommended Amplifier Power20?400 watts per channelCrossover Frequency425HzComponentsCustom-wound E-I core transformer, air core coils, polypropylene capacitors.InputsCustom 5-way bi-wire tool-less binding postsPower DrawIdle: < 1W/channelMax: 2W/channelWeight43 lbs. (19.5 kg)Dimensions59.3" ? 10.7" ? 18.8"(150.7cm ? 27.3cm ? 47.8cm)Specifications are subject to change without notice.
jslaw81 is offline
Reply Audio Gear
