Dayton audio subwoofer RSS390HO-4 15" - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-20-2013, 02:09 PM - Thread Starter
financethis's Avatar
like new in the box.
will pay half the shipping from 64118.
local pickup offered from Kansas city, mo
The Dayton RSS390HO-4 subwoofer belongs to the Dayton Audio Reference series of subwoofers. This is a Dayton car subwoofer and is built with triple shorting ring motors that utilize three short-circuit paths to almost eliminate inter-modulation distortion. This helps achieve ultra-low distortion levels on this 15-inch component speaker with one-way element. The thick anodized, 15-inch aluminum cone reinforced with an aramid fiber spider, rubber surround, extensive vents, and a four-layer copper coil handles high-power output well to provide high-quality sound reproduction. While nominal power handling by this Dayton car subwoofer is rated at 800 watts RMS, its peak power handling is 1400 watts with sensitivity at 90 dB and impedance of 4 Ohms. Other technical specifications of the Dayton RSS390HO-4 subwoofer include a frequency range of 21 Hz to 600 Hz, bass resonance Fs at 24 Hz, a magnet weight of 150 oz, and 87 dB SPL at 1 watt per 1 m. The top mounting depth of this component speaker is 6.1 inches at a diameter of 14.1 inches. This Dayton car subwoofer weighs 30 lbs and is a non-enclosed unit.
Product Identifiers
Brand Dayton
Model RSS390HO-4
MPN RSS390HO-4
UPC 844632055034
Key Features
Car Speaker Function Subwoofer
Size 15"
Type Component
Elements 1-Way
RMS Power 800 W
Technical Features
Sensitivity 90 dB
Peak Power Handling 1400 watt
Mounting
Top Mounting Depth 6.13 in.
Enclosure Non-Enclosed
Mounting Diameter/Length 14.13 in.
epson 3010 projector
marantz 1402 avr
infinity beta mains, center and surrounds
110" dalite screen
tc sounds pro 5100 subwoofers
financethis is offline
post #2 of 2 Old 04-22-2013, 10:20 AM - Thread Starter
up
marantz 1402 avr
110" dalite screen
Reply Audio Gear
Dayton Audio Rss390ho 4 15 Reference Ho Subwoofer 4 Ohm
