Audio Design Associates Suite 8300 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 05-12-2013, 09:05 PM - Thread Starter
audio4u2's Avatar
Hello
I have a near new suite 8300 Whole House Receiver. Unit is in superb shape. I am selling this as I need more zones then this can handle and it was easier to upgrade then to use the expansion unti from ADA. The price on this unit new was close to 4000.00. Includes sat radio tuners. I also have additional ADA items not listed if you are looking to build a complete system.
Shipping anywhere in the US included.
Full specs can be found on ADA website.
Thank you
Tyler
RS-232 Interface for integration with third-party control systems
Two Internal Radio Tuner Modules - Select from Standard AM/FM/WX Radio, HD AM/FM/WX Radio, Sirius Satellite Radio, and XM Satellite Radio
8 Stereo Audio Source Inputs (Including Dual Internal Tuners)
Paging Audio Input & LV Trigger - Works with Phone Suite
8 Zones Preamplified Line-Level Audio Outputs
8 Zones Class A/B Amplified Audio Output
Zones 1 & 2 Feature Line-Level Subwoofer Audio Output
Expander Connection for Linking Two Suite 8300s
ADA Bus Connector - Works With All ADA Controls
Low Voltage Source and Zone Output Trigger (12VDC)
25 Watts Per Channel @ 8 Ohms
Stable Down to 4 Ohms per Zone
115-230 VAC 50/60Hz 600 Watts Maximum
20 lbs. 5.25"H x 19"W x 16.5"D
audio4u2 is offline
Reply Audio Gear
