Rotel RSX-1057 Surround Sound Receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 06-13-2013, 08:22 PM - Thread Starter
jdeviney's Avatar
Item SOLD a while back.
350.00 local sale and pickup only in the Austin, TX USA area. 425.00 shipped in the USA at my expense.
This surround sound receiver was purchased new in 3/2007 for 1,170.00. It is in excellent condition and works as it did when new.
I do not have the owners manual or remote.
This is a 5 channel 75w x channel surround sound receiver. It is a high-end receiver with very clean power output.
Links to owners manual and spec sheets from Rotel can be found here:
http://www.rotel.com/NA/products/ProductDetails.htm?Id=19&Tab=1&Pic=1
http://www.rotel.com/content/leaflets/rsx1057-leaflet.pdf
http://www.rotel.com/content/manuals/rsx1057_eng.pdf
Model
RSX-1057
AUDIO
Continuous Amplifier Power
(Five channels driven)
75 watts/ch (20-20k Hz, <0.05% THD, 8 ohms)
(two channels driven)
100 watts/ch (1kHz, <1.0% THD, 8 ohms, DIN)
Total Harmonic Distortion
<0.09 %
Intermodulation Distortion (60 Hz:7 kHz)
<0.05 %
Frequency Response
Analog Bypass
10 Hz - 120 KHz, ± 3 dB
Digital Input
10 Hz - 95 KHz, ± 3 dB
Signal to Noise Ratio (IHF A-weighted)
Analog Bypass
95 dB
Digital Input 0 dBFs (Dolby Digital, dts)
92 dB
Input Sensitivity/Impedance
Line Level: 200 mV/100K ohms
Contour (LF / HF)
± 6 dB at 50 Hz / 15 KHz
Preamp Output Level/Impedance
1.0 V / 1K ohm
Decodable Input Signal
Dolby Digital, Dolby Digital EX, Dolby Prologic IIx, DTS, DTS_ES, DTS96/24, LPCM (up to 192K), HDCD, MP3, MPEGMultichannel
Video
Frequency Response
3 Hz - 10 MHz, ± 3 dB (Composite, S-Video)
3 Hz - 100 MHz, ± 3 dB (Component Video)
45 dB
Input Impedance
75 ohms
Output Impedance
75 ohms
Output Level
1.0 Volt
FM Tuner
Usable Sensitivity
14.2 dBf
Signal to Noise Ratio (at 65 dBf)
70 dBf
Harmonic Distortion (at 65 dBf)
0.03%
Stereo Separation (1 kHz)
45 dB
Output level
1 V
Antenna Input
75 ohms unbalanced
AM Tuner
Sensitivity
500 uV/m
40 dB
Output level
500 mV
Antenna Input
Loop Antenna
General
Power Consumption:
450 watts, Standby
6 watts
Power Requirements
(AC)
115 volts, 60 Hz (USA version)
230 volts, 50 Hz (CE version)
Dimensions (W x H x D):
432 x 162 x 442 mm
17 1/8 x 6 1/2 x 16 5/8"
Front Panel Height
150 mm, 5.9"
Weight (net):
17 Kg, 38 lbs.
jdeviney is offline
Reply Audio Gear
