KRK V88 Studio Monitors Bi-Amplified 220 Watts Oregon - AVS Forum | Home Theater Discussions And Reviews
Old 07-07-2013, 03:04 PM - Thread Starter
MONSTERguy's Avatar
KRK V88 Studio Monitors Active Bi-Amplified 220 Watts
I am the original owner and they have very low hours of use in my non-smoking home. The pair includes the original power cords, boxes, packing and owner’s manual.
Excellent condition. $640 plus shipping. Call 541-480-7437.
Want more bass? More SPL? The new V88 with two 8" woofers will definitely shake up your studio. The V88 is bi-amped, with a 60 watt amplifier for the high frequencies and a separate 160 watt amplifier for the woofer. At the input stage, the V88 is capable of receiving balanced or an unbalanced signal. A Neutrik Combo connector gives it ultimate flexibility for use with 3 different connectors (XLR, 1/4"TRS, or 1/4"Instrument). No one but KRK makes a monitor with this much output in this form factor. Video shielded? Absolutely!
V88 Specifications:
•Shielding Standard
•Drivers 1-1/4"polymere dome (HF), 2x 8” woven Kevlar (LF)
•Input XLR-1/4" TRS Combo
10k Ohm balanced
Pin1 + Sleeve = Ground
Pin2 + Tip = (+) High
Pin3 + Ring = (-) Low
•Controls Input sensitivity (+6dB to –30dB variable)
3 position switch HF Adjust: +1dB, Flat, -1dB
3 position switch LF Adjust: -3dB @39Hz, @47Hz, @55Hz
•Amplification Bi-amped: 60 watts (HF), 160 watts (LF)
•Frequency response 39Hz to 21kHz, ±1dB
•Maximum SPL @ 1m 112dB music, 115dB peak
•Dimensions (H x W x D) 13-5/8” x 20”x 16-3/4” (34.6cm x 50.8cm x 42.5cm)
•Shipping weight 57lbs (26kgs) each
ID:	584049   Click image for larger version
ID:	584057   Click image for larger version
MONSTERguy is offline
Old 11-04-2013, 07:26 AM
IceAge Cat's Avatar
Are the v88s still available?
IceAge Cat is offline
Old 11-04-2013, 12:24 PM - Thread Starter
MONSTERguy's Avatar
Yes. Call the number in the ad to buy.
