Linn Majik and Linn Genki - Integrated Amp and CD Player - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-11-2013, 04:28 PM - Thread Starter
ahartig's Avatar
Liked: 127
$600 a piece or buy both for $1000
Must sell... great condition, see pics.
Linn Majik Info:
This gently used Linn integrated amp has a Sneaky Module built-in Kudos AM/FM tuner. The Majik-1 delivers 66w per channel into 4 ohms/ 33w per channel into 8 ohms. The Majik produces room-filling rich music reproduction, and can hold it's own with today's 100+ watt amps any day. Inputs include Phono/CD/AUX/TAPE. The case has no scratches or blemishes. This amp has been carefully boxed and stored in a dry and clean environment since 2009. Prior to that it was used carefully and kept in a clean/smoke-free home. Since I am not using this amp, I have decided to let it go. It will be shipped in original box with manuals. Check out Linn's website for more information: Linn site: http://www.linn.co.uk/all-products
Power Consumption:
320VA maximum, 25 Watts idling
Power Amplifier Specification:
Input impedance: 10 KOhms
Voltage gain: 28.5dB
Input sensitivity: 592mV rms for 16.2V rms output
(33 W into 8 Ohms)
Power output: 66W per channel into 4 Ohms
33W per channel into 8 Ohms
Linn Genki Info:
Specifications:
Type Spacer CD player
Analogue Outputs Spacer 2 pairs single-ended stereo analogue audio outputs
Output Level Fixed Spacer 2Vrms (peak code)
Output Level Variable Spacer to 2Vrms (peak code)
Digital Outputs Spacer SPDIF digital audio electrical output
Conversion Technology Spacer Delta-Sigma at 24-bit resolution with HDCD� decoding
Mains Supply Spacer Brilliant Slimline Power Supply
Power Consumption Spacer 20VA approx
Size Spacer W 320 x D 325 x H 80mm
Weight Spacer 3.3kg
MSRPt Spacer $1,950 USA Black or Silver
XBOX Live ID: HONDEboyMAN
PSN ID: ahartig
ahartig is offline
post #2 of 2 Old 10-29-2013, 11:39 AM
kim108's Avatar
Hey where are you located? do you still have the Linn Majik and CD also the Plinius 8200p?
Kim
kim108 is offline
Reply Audio Gear
